Forum: Analog Circuits Zener diode-to protect_BJT
Author: Daniel-p (Guest)
Could any body please help me with the following problem:
As shown in the attached picture I have 2 networks, network-1 and
network-2. Network-2 should takes current out from the capacitor(charge
it to negative voltage levels).
Transistor must be off during the charge period.
Problem:The zener diode I used to protect the transistor provides a
current path while the voltage level in the capacitor becomes smaller
than zero, therefore I can't charge the capacitor!!
How can I solve this problem?
thanks a lot in advance
Author: oszi40 (Guest)
Sorry I think I should modify the question:
network-2. Network-1 charges the capacitor to positive voltage levels
and network-2 charges it to negative voltage levels.
the network-1 must be seprated from the capacitor for the time in which
the network-2 is working. I have selected a BJT as a switch to break the
path when network-2 is working.
(Transistor must be off during the negative charge period)
Question:
1-since the capacitor is charged to positive voltages is a protecting
zener diode necessary?when yes how should it be connected?
2- Or a zener diode is required because of negative voltages on the
capacitor?when yes how should it be connected?
Note: care must be taken that the zener diode doesn't provide an
unwanted current path while charging to negative voltages(no current
path through this BJT).
How can I solve this problem? or any other idea?
webmaster@embdev.netContactAdvertising on EmbDev.net
