Forum: µC & Digital Electronics Get Binary-Data from Wav-File
Author: Samuel_Schmid (Guest)
Hello
I want to play a sound with a microcontroller. I have the whole circuit
but I hava a problem with the sound data.
I have the sound in a wav-file but I'm not able to get the binary-data
out of it. Does anybody know how I can get this data out of a wav-file?
Thanks a lot
Samuel_Schmid
I wonder if you even tried to search the net a little bit. You may start
here: http://en.wikipedia.org/wiki/WAV and follow the links.
Some code for "inspiration" may be found in Atmel's Examples for AT91,
AVR, AVR32... from atmel.com. IRC I have also seen code to read
WAV-Files in at least one of the examples. There is also a "WAV to
ADPCM" converter (for PC, with source-code) in the Atmel
Application-Notes for AVR. In example-codes from Sharp for ARM-based
controllers there have also been WAV-decoding functions (search nxp.com,
they acquired this business-section from Sharp). Check Microchip's
AppNotes, ST Microelectronics STM32, STR7, STR9 AppNotes...
Author: Gerhard (Guest)
you might look at SoX (Sound Exchange Program) at
http://sox.sourceforge.net/. There is also a Windows executable. You can
use it to create the pure binary data from a Wav file.
Gerhard
Author: Mirko Horstmann (m1rk0)
Or, if you are looking for a programming library, libsndfile can import
quite a lot of audio formats: http://www.mega-nerd.com/libsndfile/
Mirko
Author: Drachenbändiger (Guest)
Your question is not really specific enough to permit a clear answer.
Let me guess: Is this what you are after? wav2c:
http://en.pudn.com/downloads105/sourcecode/speech/...
Here is another link (no login required) for wav2c :
  http://github.com/olleolleolle/wav2c
Thank you very much for your answers.
I think the way2c is the right thing for me. But it seems like I have to
compile this program first, before I can use it. Does anybody know how I
have to do that?
Samuel_Schmid
Here is a precompiled version: http://darkfader.net/ngpc/files/wav2c.zip
Thank you very much Drachenbändiger. It works.
I'm going to try the binary data as soon as posiible. I hope it sounds
well.
Is it right that I have to do the 2-Complement with the generated data
from the binary file or do I have to do that only in a 16-Bit Wav-File?
Thanks
Samuel_Schmid
You can feed the data directly into a D/A converter (for 8 bit data, I
use a simple R2R network). Remove the DC component with a capacitor
before you amplify the sound.
webmaster@embdev.netContactAdvertising on EmbDev.net
