Forum: µC & Digital Electronics RTEMS or FreeRTOS on STR712FR (ARM7 TDMI)
Author: Marchaudon Romain (Guest)
Hi everyone,
I was looking into some informations about the possibility to use RTEMS
on a tiny µC with an ARM7TDMI included (this is the STR712FR, but for
the moment I don't know if it's the 0, 1 or 2 ...)
I have seen that this is possible to reduce the size of the kernell with
RTEMS, but I still don't know how many KB of RAM and flash I need to
make it run :S
Also what do you think about FreeRTOS? Better that RTEMS on a µC?
I'm sorry but this is the first time in my life I have to use a RTOS
(I'm a trainee ...) and I'm getting issue finding those informations.
Thans a lot.
Romain
Author: Romain Rominou (Company: Viveris Technologies) (heero_91)
I have had the information from my project manager, the µC is the
STR712FR2 which have 256+16 KB of flash and 64 KB of RAM.
So do you think this is possible to put RTEMS or I should use FreeRTOS
or µClinux?
By the way, why the flash memory is presented as 256+16? What's the
interest?
Thanks a lot
Romain
no-one can answer me? For the moment I can't test on my hard (I'll
receive it in few weeks) but I need to know in order to devellop
properly.
Since you did not mention external Flash- and RAM-Memory I don't think
there is a chance to get ucLinux working. I have not worked with RTMS
but as far as I know it also needs more memory as the controller offers
internally.
FreeRTOS should be o.k. if you need a small, well-documented and free
RTOS. You may take a look on ChibiOS/RT which offers similar
functionality and a comparable license.
Please note that uClinux and RTMS offer a lot of more functions and
drivers. But it's not that difficult to extend the STM STR7-StdPerphLib
with synchronisation-code (e.g. mutexes) in case different tasks/threads
access the same peripheral. Using the STM-STR7-Library as base should
save some time.
Author: 900ss (Guest)
Martin, do you have experience with the ChibiOS/RT? It looks interesting
but I didn't find the time to run a test.
If you have experience, are you satisfied with that OS? Can you suggest
it?
Thanks, 900ss
Sorry to "UP" this topic but I'm still on the choice of the OS so far on
the project (I'm not making the choice, just doing the research, my
project manager is making the choice).
With your informations and others I have found on the Internet, I can
say that RTEMS will not be abloe to run on my µC!
But you have said that I should have a look on uClinux, and this is what
I am doing ... And I have seen that it still needs too much memory
(arround 500KB apparently ... But I am not sure). Anyway the interesting
part is that I can use a dbg with this OS, which is very interesting,
but with the memory problem so far I should not be able to use the OS on
my board :(.
I know that there is, on uClinux, a TCP/IP stack, and I don't need this.
Is there any way to remove component from uClinux in order to decrease
the size ok the kernel? I can't find info about this on the uClinux
website so far, and I'm still searching!
Or maybe I'm just wrong and this is possible to run directly uClinux on
256+16 KB of flash and 64 KB of RAM, inernal to my µC?
Thanks a lot for your answers.
Romain Marchaudon
webmaster@embdev.netContactAdvertising on EmbDev.net
