Forum: ARM programming with GCC/GNU tools c defined variable offset in asm
von Euler M. (logaritmuseadx)
Working with WinARM2006xxxx (gcc v4.1.1), I am trying to access a
variable defined in a c module from an assembly file in the following
way:
ad.c:
short int ADBuffer[ADBUFFER_N];  //global
short int* pADIn _attribute_ ((section (".ocram"))) ; //global
fiq.s:
   LDR  R8, =RamVariableBase  //#OnChipRamBase, 0xb00000
   str  r10, [r8, #AD_IN_PTR_OFS] //store rd ptr
this works ok, but i need to know AD_IN_PTR_OFS.
I would like to do something like:
   str  r10, [r8, #(pADIn-0xb00000)] //store rd ptr
my gcc parameters:
arm-elf-gcc -g -O2 -march=armv4 -mtune=arm7tdmi -nostdlib
-fomit-frame-pointer -fno-strict-aliasing -Wall -Wl,-T,crx.ld
-Wl,--section-start,.ocram=0xb00000
I would appreciate sharing your knowledge, experience regarding this
issue!
Thank You!
Euler
von Stephan M. (stephanm)
I'm unsure if I understood the intentions of your code, but to me it
looks like you're basically looking for the following:
ldr r9, =pADIn /* Load address of pADIn (which is a pointer) */
str r10, [r9] /* Update pADIn (i.e. pointer value) */
Stephan
