Forum: ARM programming with GCC/GNU tools Preventing function from using a specific CPU register
Author: jrmymllr jrmymllr (jrmymllr)
I have an assembly function which is called by the fault interrupt.
This assembly code places the stack pointer (SP) into a register (r0).
This assembly code then calls a C function which has one parameter, and
the value value of r0 gets passed into it.  The problem is, the C
function messes with r0 at the beginning and sometimes trashes it.  It
never returns from this C function since its job is to display fault
info on an LCD, then the micro must be reset.
So, how can I prevent GCC from using a specific register so its
integrity is maintained?
Author: Abdul K. (ehydra)
I don't know about GCC, but 'register' is the standard.
Author: A. K. (prx)
There is no such thing as a "standard" for an inherently nonstandard
operation ;-). Nevertheless GCC does have a (very nonstandard) way to
assign specific registers and it does indeed use the keyword "register".
See http://gcc.gnu.org/onlinedocs/gcc/Explicit-Reg-Vars.html.
Note though that this could turn out to be an answer to the wrong
question. I do not understand what you really want to achieve. And a
function should no trash its parameter if it is used later, though it
could move it to some other place.
Author: Rolf Magnus (Guest)
Why does that C function overwrite its own parameters before using them?
OK, read 'common'.
An example is Keil C51 and Cypress PSoC. I don't remember the right one.
There is a short parameter passing within registers, and a long
parameter passing in the 'common' way on the stack. Parameter lists
exceeding the free register map are loaded on the stack.
If Assembler and C think different, the code crashes!
Author: mizch (Guest)
I assume you're talking about AVR CPUs.
Then, r0 is a poor choice for parameter passing, since it is the target
of some assembly language instructions (lpm and mul come to mind).  They
overwrite r0 and I doubt any compiler will take care of saving r0 before
and restoring it after those particular instructions.
Sorry, youst see you're taking about an ARM.  Forget my comment above.
Author: Axel H. (axelh)
APCS says that function parameters are passed in r0 to r3. And this
usually works fine when calling C-Code from assembler code. So it
appears there is a problem with your C function. How does it look like
and what is the assebler code that is generated by the compiler?
I think I need to elaborate a bit.  This is an ARM Cortex-M3.  I'm
trying to write a fault handler that will display the fault exception
stack on my LCD.
So I have this function, which is the ISR for any faults:
IntDefaultHandler:
     TST LR, #4
  ITE EQ
  MRSEQ R0, MSP
  MRSNE R0, PSP
  b hard_fault_handler_c
I didn't come up with this strategy as it seems to be a common way of
writing a fault handler.  But the idea is that the C function will take
the contents of r0 as the first parameter, which should be the location
on the stack that contains the fault exception frame.
Initially, the above code was inside a C function using __asm() but GCC
put some extra instructions at the beginning.  So I moved it to a
assembly file.
Here's essentially what is in hard_fault_handler_c:
void hard_fault_handler_c(unsigned int * hardfault_args)
     unsigned char y[20]; //used for string processing
     //display hardfault_args[0], hardfault_args[1]...hardfault_args[7]
     while(1);  never leave
But, in looking at the generated asm I see that GCC is messing with r0:
   10e30:  b580        push  {r7, lr}
   10e32:  b088        sub  sp, #32
   10e34:  af00        add  r7, sp, #0
   10e36:  6078        str  r0, [r7, #4]
What happens sometimes is that hardfault_args is one word, 4 bytes,
offset from where it should be.  I'm going off the assumption that the
asm code at the start of hard_fault_handler_c is modifying r0.
So, that's why I'm trying to prevent hard_fault_handler_c from modifying
r0.  Or, if there's a better way, I'd gladly do that.
Author: A. K. (prx)
The assembly code shown above obvously is not messing around with r0, it
just saves its contents to some place on the stack. Maybe because there
is some significant amount of varables handled before the parameter is
used, so the compiler frees r0 for better use, or maybe because
optimzation is disabled and the regular unoptimized place of variables
is in memory.
Author: A. K. (prx)
A failsafe version of a hard fault handler should initialize its stack
pointer with a known safe value before first use within the handler,
because one likely reason of a hard fault is an invalid stack pointer
value.
Author: A. K. (prx)
Are we talking about unimplemented interrupts in general or about the
CM3's hard fault vector? For unimplemented interrupts, you may safely
assume a valid stack frame. Not so for true hard faults however, because
the hard fault handler may get entered because some stack push operation
by a regular fault handler failed. So it is not safe to assume a
regular exeption frame on the stack on entry of the hard fault handler.
Look at BFAR.
Author: A. K. (prx)
Correction: The bus fault status register should be consulted prior to
any assumption on stack contents.
If bus and memory faults are enabled, the same caution could be
necessary for them as well. IMHO the CM3 core manual isn't very clear in
this respect.
If it 'sometimes' occur, than think of the possibility of an stack
overflow.
> overflow.
I should be more clear on "sometimes".  My stack is definitely not
overflowing.  I've checked and it's far from hitting the limit.
What I've done is placed artificial bugs in different areas that I can
trigger selectively.  I write a value to an invalid memory location to
test the fault handler.  There are three of these artificial bugs.  Two
of them generate a correct pointer to the stack frame.  The third one
generates a pointer to a stack from that is offset by 1 word.  It's
perfectly repeatable.  My code in general is stable; I just want a good
fault handler in case it does fault.
> Look at BFAR.
It would be great if I could just display BFAR, but it never seems to
contain a valid value.  The only time I've gotten it to display a valid
value was when I (intentionally) wrote to a peripheral without enabling
it first.  Otherwise, BFAR contains it's own address after the
artificial bugs I've introduced (see my previous post about that)
> is in memory.
Ok, yes you're correct.  I'm not an ARM asm expert and was interpreting
the str instruction incorrectly.
>> Look at BFAR.
Sorry about all the posts.  I'm dealing with the hard, bus, and usage
fault vectors.
Author: Marcus Harnisch (mharnisch)
Maybe you didn't actually have a bus fault.
> can trigger selectively.  I write a value to an invalid memory
> location to test the fault handler.  There are three of these
> artificial bugs.  Two of them generate a correct pointer to the
> stack frame.  The third one generates a pointer to a stack from that
> is offset by 1 word.  It's perfectly repeatable.
This is great, so can tell us exactly what the respective stack
pointer values were immediately before the fault was triggered and
what the r0 looks like immediately before entering
hard_fault_handler_c(). It might also help to see a little more of
hard_fault_handler_c()'s code.
Note that Cortex-M3 supports optional automatic exception stack
alignment. If the stack was less than eight byte aligned when the
exception occurred, exception entry will subtract four (a word) from
the stack pointer.
Marcus
http://www.doulos.com/arm/
I think it is, because CFSR indicates an imprecise bus fault, and if I
put a unique function in the bus fault location on the interrupt vector
table, it jumps to it.  However, the plan is to have hard, bus, and
usage faults vector to the same function.
I'll collect this information later today and post here.
As for what is in hard_fault_handler_c(), I'm just using a sprintf type
function to place the string in "y", then a function I wrote that
displays "y".
usprintf (y, "R0:   0x%08x", hardfault_args[0]);
lcd_DspStr(y, LCD_LINE_NUM(20), INVERT_OFF, Terminal6x8);
//and repeating for hardfault_args[1], hardfault_args[2], etc
> the stack pointer.
I found this information, but am a little confused by it.  At first I
thought if the value of (in this case) r0 wasn't evenly divisible by 8,
I'd adjust it by one word.  However that didn't reliably fix it.  So
then I tried setting STKALIGN during initialization.  That didn't fix it
either, and actually might have been worse.  I don't know if what I
tried is correct, but it was how I interpreted it.
> Marcus
With imprecise faults all bets are off anyway. An imprecise fault may
be pended and can occur way after the offending instruction has
executed. Registers might have changed and therefore the stack might
not contain information that is helpful in nailing down the issue.
So you are saying that two of your injected faults are behaving
nicely. Are these two also triggering imprecise faults? If these two
are precise faults and only the "odd" one is imprecise you are done.
What you also need to tell us is how you make the exceptions reuse the
same handler. Are you putting the same function name into the vector
table with all these exceptions enabled or are you taking advantage of
fault escalation?
Thanks.
>> alignment.
Of course not. If your SW (printf perhaps) depends on an aligned
stack, aligning r0 doesn't help. The stack pointer register (MSP or
PSP needs to be aligned). Since a copy of your stack pointer will be
stored in r0 it'll consequently be aligned, too.
> So then I tried setting STKALIGN during initialization.  That didn't
> fix it either, and actually might have been worse.
In which way?
Marcus
All three are imprecise.  CFSR is 0x400 and BFAR always contains it's
own address with any of the three faults.
> fault escalation?
I'm putting the same function name into the vector table.  Although, I
could just as well not enable the other exceptions and let it escalate
to the hard fault, if that is preferable.  Actually I was doing that for
awhile, but now it doesn't make sense to do that if I'm using the same
handler.
>>> alignment.
I'm not sure if usprintf depends on an aligned stack.  But, in using the
JTAG debugger in hard_fault_handler_c() I can see that r0 in these cases
points to the incorrect stack location, at least based upon what the
stacked PC should approximately be.  When r0 doesn't point to the
correct location, it's always one word away from what seems like a
plausible stacked PC value.
> In which way?
I'll have to go back and check this one when I can get to the setup
later, but it seems like r0 was incorrect even for the injected faults
that previously produced good results.  But, I need to verify this one.
I had high hopes STKALIGN would fix my problem, but it didn't so I
abandoned it shortly afterward.
> Marcus
Imprecise aborts don't update BFAR.
> handler.
An escalated imprecise bus fault won't be pended but force the handler
to be called.
But what did r0 look like before entering hard_fault_handler_c()? In
other words, did r0 ever contain the expected value?
Marcus
Good question.  I'll check this too.  For some reason the registers
don't always appear in my Eclipse/OpenOCD setup.  I don't know which is
at fault, but I can get them to appear sometimes by restarting the
session or restarting Eclipse.
> Marcus
Here's what I found: the value that r0 acquired in IntDefaultHandler
(the asm ISR) was passed to hardfault_args in hard_fault_handler_c()
every time intact, and stayed intact.
I actually added a fourth "bug" in a completely different function to
make things interesting.  It's the exact same errant code as the other
three bugs.  Below is a summary of how each fault behaves.  I'll number
each function that contains a bug.  Remember that one function contains
two faults that can be separately activated; one fault in this function
is inside an if(), and the second one is inside a corresponding else
if().  The if() and else if() each have their own local variables that I
assume would have to be pushed onto the stack.
Function  "Bug" Address   Correct?            Stacked PC        r0
#1            0x100D8       correct             0x100E6    0x20002ED8
#1            0xFF7E        incorrect (in LR)   0x18E0     0x20002ED8
#2            0x5C28        incorrect (in LR)   0xD90      0x20003030
#3            0x3D48        correct             0x3D5A     0x20003028
The second column is the address of the instruction that writes to an
illegal address and causes the fault.
The third column indicates if the stacked PC value seems correct; if
not, I indicated what position it appears in.  So, for this data, when
the stacked PC value didn't seem correct, I instead found the value that
I believe should have been the PC in the LR position.  In other words, I
believe that r0/hardfault_args is one word too small in these cases.
The fourth column is the value in the stacked PC position.  In the
"correct" ones, the stacked PC value is very close to the "bug" address.
In the "incorrect" ones, I found a similarly close value offset by one,
in the stacked LR position (if r0/hardfault_args is pointing to the
stacked r0 value, then stepping thru the rest of the stacked values: r1,
r2, r3, r12, LR, PC).
The last column is the pointer to the supposed stacked r0 value, in
other words, r0/hardfault_args.
As for STKALIGN, I tried writing 0x20 to it at initialization, and it
made no difference.
Jerry Milner wrote:
> So, for this data, when the stacked PC value didn't seem correct, I
> instead found the value that I believe should have been the PC in
> the LR position. In other words, I believe that r0/hardfault_args
Would that assumption correspond with the other stacked register values?
Try disabling Bus Fault and Mem Manage Fault and escalate them to Hard
Fault. See if that makes a difference.
Again: The observed faults are imprecise and that means the return
address may not be related to the instruction that caused the
abort. The fact that you see a "close" value in stacked lr might just
be a coincidence.
Marcus
I frequently see the same/similar values in the immediate vicinity, but
can't say for sure how consistent that is unless I start keeping track.
I do however frequently see 0xfffffff1 or 0xfffffff9 in the word after
the pointer, and usually see the invalid address I'm writing to in the
vicinity (0x30000000).
I'll try that later today when I'm able to get to the setup and I'll
report back.
> be a coincidence.
Understood, and I can't safely assume anything.  However, in the case of
the two faults that are providing incorrect stack pointer values, I
believe the probability of both containing a plausible stacked PC value
in LR strictly by chance is fairly small.  Is it possible that LR would
contain the return address?  The CM3 manual says:
The LR receives the return address from PC when a Branch and
Link (BL) or Branch and Link with Exchange (BLX) instruction is
executed.
The LR is also used for exception return.
Maybe there's a good way to identify more markers I could use, for
example, if I could display the values of r0-r3 and r12 immediately
before the faulty line of code, then try to match it up with the stacked
values?  I'm not sure how well that would work.  It might be worth a try
I certain special cases perhaps. One instruction causes an imprecise
(asynchronous) fault. A subsequent instruction is a BX lr which
returns from a subroutine. The exception executes right there. If the
timing is just right, I suppose the exception return address (stacked
pc) could be the same as stacked lr.
Yes, but not as return address. It is used to inform the exception
exit how to return. The return address comes from the stacked pc --
always.
That's what I meant with this:
Marcus
Just something to add I discovered.  The stacked PC values that seem to
be incorrect are in fact the addresses of functions which are called
very soon or immediately after the faulty line of code.  So this would
seem to explain things, but LR's purpose must be to contain the return
address back to the original function.
Jerry Milner wrote:
> The stacked PC values that seem to be incorrect are in fact the
> addresses of functions which are called very soon or immediately
There you go.
> So this would seem to explain things, but LR's purpose must be to
> contain the return address back to the original function.
Not in case of exceptions. It only appears to be the case to keep the
programmers model as simple and straightforward as possible. That way
you can return from exceptions and subroutines the same way. Note that
this is unique to ARM Cortex-M processors. Other ARM cores use a
different model.
Marcus
> There you go.
> different model.
> Marcus
I disabled the other exceptions, forcing them to escalate to hard
faults, and get the same results.  So I think it's safe to say this is
working as it should, but maybe not as I expect!
