Forum: ARM programming with GCC/GNU tools startup_lpc17xx.s GNU
Author: Stefano (Guest)
I have installed Sourcery G++ Lite compiler in Keil IDE.
Now I start to try to compile a simple Keil example (IOTest) for LPC1768
Cortex M3.
The assembler language is different and I need to replace the file
startup_lpc17xx.s, where can I find the correct version for Sourcery
assembler ?
Thanks
> Cortex M3.
> assembler ?
NXP provides a "CMSIS-Complient Driver Library" on it's web-site.
Filename is lpc17xx.cmsis.driver.library.zip. There is startup-code for
gcc in this package (search .../gcc/startup_LPC17xx.s).
If have not worked with LPC17xx so far but please note that the
startup-code in the Keil/ARM-examples often includes additional
instructions in the assembler-setup (e.g. for PLL, clocks). But there is
initialistaion-code for these settings available in system_LPC17xx.c in
NXP's archive so porting should be easy.
Thanks !!!
OK, now I can compile without problem, but when link with ld.exe I have
the following errors:
startup_LPC17xx.s:132: undefined reference to `__cs3_stack'
startup_LPC17xx.s:132: undefined reference to `__cs3_reset'
startup_LPC17xx.s:132: undefined reference to `__start'
Perhaps I should add some parameters .......
What can I do for solve this error ?
Thanks
It seems that the used linker-script is incompatible with the
startup-code. The undefined symbols get defined by the linker since
there are instructions for this in the linker-script. The symbols are
basically variables which hold memory-addresses (for example top of
stack) and are later used during assembly of the startup-code.
Did you use one of the linker-scripts which come with NXP's package
(*_gnu.ld)?
OK, now I have in added the linker-scrpt file *.ld, the syntax is very
complex and the example file is very long.
Do you have a simple script-file for base configuration that can send to
me.
Thanks
Sorry. I do not have a simple ready-made linker-scripts which are
compatible with the LPC17xx startup-code from NXP. I do not own a board
with such a controller so I had no reason to create anything for it. But
if the scripts and startup from NXP work just use them for now. You can
read more about linker-scripts an the instructions in it in the binutils
ld manual. The scripts from NXP seem to be based on the Codesourcery
"standard" for linker-scripts and startup. IRC there is some information
on this in the "getting-started" PDF-file included in CS G++ lite.
Maybe this is useful for you:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
It's for another controller also with Cortex-M3 core and it should be
rather easy to port the linker-script and startup-code to LPC17xx.
Decide yourself if it's "simple" enough
Maybe someone else can jump in here and provide "simple" an tested
examples for LPC17xx.
OK, now I am near able to work.
I have an other question about CodeSourcery in Keil:
- The "download code to flash memory" is no longer enabled, then I
cannot program the target, is possible enable this function ?
- The debugger function remain limited to 32K ? or is possible to debug
code long more then 32k ?
Thanks in advance
The forum/support-request-form at keil.com might be a better place to
ask questions on µVision.
Did you verify that Options for Target/Utilities is configured correctly
for the used interface? Is an elf-file generated? Did you try with
"generate hex-file" enabled in the project settings. The download
function worked for me even when using the GNU cross-toolchain at least
with older versions of the evaluation-software. I have not played with
the latest version.
As far as I know: yes. The limiation of the debugger and simulator is
not related to the used cross-compiler.
> or is possible to debug code long more then 32k ?
Keil/ARM sells unlimited versions and IRC also a less expensive package
with 256kBytes limitation.
