Forum: ARM programming with GCC/GNU tools Problem with UART example running in RAM for lpc2148
Author: Kristina Pavlovska (Guest)
I'm very new at ARM and GCC tools. I work with lpc2148 and ARM-USB-OCD
debugger. I successfully installed Eclipse with Yagarto and tried few
projects to run them in RAM. But when I start working on the
lpc213x_lpc214x_examples by WINARM (for example UART) I couldn't change
successfully the make file as well as the linker file so that they can
run in RUN_MODE=RAM_RUN and not in flash. Actually I made few changes
and build the code but somewhere in the Startup.s returns error: address
+ size wrapped
I would be most grateful if someone can give me advice on this problem
since I don't know if it is as a result on the changes that I have made
in the make and linker file. I read in the readme file of WINARM that
the RAM_RUN mode hasn't been tested by the authors.
Thanks in advance,
