Forum: ARM programming with GCC/GNU tools address from where booting starts
von Robert S. (Company: wse labs) (arm-and-leg)
Can  any one tell from which address (in Flash)the booting starts in
embedded  systems .
von Drachenbändiger (Guest)
Don't be surprised at the lack of replies to your question. You need to
be much more specific if you want people to come up with reasonable
answers:
- Which processor are you referring to?
- To me, the term "booting" implies that an OS is involved; please
specify which OS you have in mind.
One more thing comes to mind: Maybe you are not referring to an embedded
system running an operating system, but to a system with a boot loader.
Please clarify.
it is  a generic question , you can take ATEB9200 board to answer .
 I wanted to know when i switch on a ARM based SBC .. from what address
 booting process initiates like for
 eg. Boot rom in chip will load the bootloader  from
____________address in flash.
 Is this address fixed ? , how it is pre-configured?
You have to read the data-sheet/manual of the microcontroller. Some
chips have external pins to set the start-address and/or remapping, some
have non-volatile-settings to configure the start address. So the
question can not be answered in general. Most "small" SOC with internal
flash I know start from address 0.
Thank you martin , atleast i got some reply
von jrmymllr j. (jrmymllr)
Your original question was extremely vague; that's why you got the
initial response you did.  It's like asking "what is the voltage of most
batteries?".  There could be a good answer to that question if it was a
little more specific.
i got the idea ... next time will include more specs.
von Clifford S. (clifford)
Next time you'd do better to read the data sheet and/or user manual for
the device you intend to use.
