Forum: ARM programming with GCC/GNU tools Device drivers and ARM learning
von Robert S. (Company: wse labs) (arm-and-leg)
Dear experts ,  i am  a developer in embedded space.
 i did work with some app layer modules .But I know nothing about the
 low levels .
  I want to learn ARM board firmware as well device drivers developments
 But cant afford to buy a 100$ kit.
 So i decided to go hacking route , found the linksys wifi routers can
be hacked .This will enable me to do a few drivers , buy these ase MIPs
but these are MIPs .
 can u suggest ARM box for me to hack ?
 how can i learn the boot process of linux?
 how to debug USB drivers , what mechanism available?
 How to approach  for a driver development  ?
 Please help
 -ARM newbie
von jrmymllr j. (jrmymllr)
These are all good questions, but the answers you're probably looking
for would fill a large textbook.  My suggestion is to start searching
the Internet for some of the easier questions first.  It seems like you
need to start with some easy stuff first, because it would take me weeks
to start understanding what you're looking for (because I don't
understand USB, booting Linux, or writing Linux drivers, either)
von Sebastian (Guest)
It depends on whether you want to develop applications for a full
embedded OS (usually Linux), a RTOS (linked together with the
application into a monolithic binary) or if you'd rather write a "bare
metal" application which does not use an operating system, but accesses
the hardware via driver libraries.
Furthermore, there are different ARM families in use, most notably ARM7,
ARM9, ARM966T and Cortex-M3. These cores are embedded in micros from
various manufacturers, like Atmel (AT91SAM, AT92RM), NXP (LPC2xxx), STM
(STR9, STM32) and others.
On the smaller, ARM7-based variants a full OS can not be run due to
memory restrictions mostly. But they are cheap and easily available if
you can live with using a RTOS, which allows you task scheduling and
such, often handles additional things like TCP/IP if available), or
writing all needed functions by yourself. ARM7-based boards are fairly
easy to build for the hobbyist, and most solutions are cheap and
single-chip.
If you want to go all the way, though, you could look out for readily
available ARM-based hardware, which is not only found in routers. The
Philips VP6500 IP-Phone is a hackable linux-based ARM platform recently
discussed here in Germany, for example.
