Forum: ARM programming with GCC/GNU tools #define problem
von jrmymllr j. (jrmymllr)
Say I define this:
#define MENU(A, B, C, D) lcd_DspStr("A  \x29  B  \x29  C  \x29  D")
Then do this in my program:
MENU(\x30, \x30, \x30, \x30);
lcd_DspStr() is a function I wrote to write to my LCD and it works fine
when placing text straight into the quotes.  In this case, I'm using a
special font that contains symbols, rather than ASCII characters, so
that's why I'm using "\x30" or similar.  It works perfect if I forget
about using the #define.
Anyway, I would expect this setup to work, if it replaced A with \x30
and so on.  But it doesn't.  It compiles fine, but I get weird results
so the define is obviously not doing what I thought it would.  Where am
I going wrong?
von Rolf Magnus (Guest)
> I going wrong?
#define doesn't replace anything within a string.
Try:
#define MENU(A, B, C, D) lcd_DspStr(#A "  \x29  " #B "  \x29  " #C "
\x29  " #D)
von Clifford S. (clifford)
What Rolf said.  For reference:
http://www.cppreference.com/wiki/preprocessor/sharp
For the purposes of Googling the # used in this manner is called the
"preprocesor stringization operator"
von kbuchegg (Guest)
And the other thing Rolf used, is the fact that the compiler has to
catanate strings on its own if they aray not seperated by some other
character then whitespace
   "Hello" " World"
is identical to "Hello World"
So he first used the stringize operator in
#define MENU(A, B, C, D) lcd_DspStr(#A "  \x29  " #B "  \x29  " #C " \x29  " #D)
with a macro call of
to first have A, B, C, D replaced with the given macro arguments, where
each argument is enclosed in quotes (by the stringize operator), which
gives
  lcd_DspStr("\x30" "  \x29  " "\x30" "  \x29  " "\x30" " \x29  " "\x30")
which in turn is string-catanated by the compiler to become
  lcd_DspStr("\x30  \x29  \x30  \x29  \x30 \x29  \x30")
... the intendet result.
Thanks everyone.  This fixed my problem.
