Forum: ARM programming with GCC/GNU tools minicom is not detecting the target board
Author: Ashutosh Mahto (Company: student) (ashutoshmahto)
I am using ARM 1020TDMI development board.I have burned the bootloader
using JTAG.I have set up a minicom at terminal ttyS0.However on powering
up the device,the minicom is not able to access the board.it does not
show any error message and neither the target board does not boot.
please send detailed steps of configuring the minicom and enabling the
serial port for accessing the board.
thanks in advance.
Author: Heiko (Guest)
I know of one typical problem concerning serial port setup - which is
flow control. Many PC terminal programs use flow control by default,
many embedded projects don't - so you need to turn off flow control.
Just a quick guess,
Heiko
thanks for the reply but i have already done that without any
improvement.
This could be caused by any number of problems, but you seem to be
blaming the least likely cause.  Most issues would be down to your code
running on your target.  Since you have a JTAG device, you should use
that to inspect the UART registers on the target to determine whether it
is correctly set up, and to see whether the UART is receiving any data
(send a single byte and inspect the Rx data register). You should also
use the JTAG with GDB to debug the bootloader code.
A common error is an incorrect baud rate generator configuration.  You
might use an oscilloscope to test the bit/character width. If you have
an incorrect PLL configuration, the UART may not be running at the rate
you intended either.
A useful tool you can use at the PC end is Portmon; this sits between
the serial port driver and the terminal emulator, and provides
information of exactly what data is being transmitted and received as
well as what ports are opened and othe OS calls to the driver.  It is
essential for serial comms debugging.  Portmon may not work with some
USB serial port adapters; if this is the case you cab use "HDD Free
Serial Port Monitor", this is less flexible that Portmon, but works in
more cases.  Once HDD is monitoring a port, it is sometimes possible to
then attach Portmon where it does not work when connected directly to
the device driver.
http://technet.microsoft.com/en-us/sysinternals/bb...
http://www.serial-port-monitor.com/
webmaster@embdev.netContactAdvertising on EmbDev.net
