Forum: µC & Digital Electronics Watchdog with ATTiny 2313 not working
Author: Peter (Guest)
Hello,
could someone please help me?
I'm pretty new at this. I tried to make a simple watchdog that resets my
server when it freezes.
I have made a windows program which sets one bit of the parallel port
every minute for a second. The Attiny 2313 is programmed that is resets
the server when this doesn't happen for more than ten minutes.
I have connected the attiny 2313 to the following pins:
+5V --- to +5V on the mainboard connector
GND --- to one of the GNDs from the parallel port
PB0 --- (as input) to the pin on the parallel port which is set by the
windows program; and a 10k resistor which is connected to GND on the
other end
PB7 --- (as output) to the reset pin on the mainboard connector
Behavior: when the windows program isn't running, the server resets
after 11 minutes (as it should)
When the windows program is running, the server runs for about 20
minutes and then resets (it shows that i use the correct pin of the
parallel port, at least).
Maybe someone has an idea what i did wrong?
Here is the c-code:
#include <avr/io.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#include <inttypes.h>
int main(void) {
  int timer;
  int value;
  int oldvalue;
  const int TIMERMAX = 6000;
  DDRB = 0xFE; // 11111110 - PB0 is input
  PORTB = 0;
  oldvalue = 0; timer = 0;
  while (1) {
    if (bit_is_set(PINB,0)) { value = 1; } else { value = 0; }
    if (oldvalue != value) {
       oldvalue = value;
       timer = 0;
    timer++;
    _delay_ms(100);
    if (timer > TIMERMAX) {  // no change on PB0 for more than 10 min.
       PORTB = 0x80;    // set PB7 to 1
       _delay_ms(100);
       PORTB = 0;
       timer = 0;
  } // while
Thank You very much for Your help,
Peter
Author: MagIO (Guest)
Sorry ... I don't use AVRs currently, but as nobody else replies .. here
are my 2 cents:
I'd simply use the good old LED-debugger to watch what the AVR thinks it
sees on the parallel port. Did you check the LPT with a scope?
I remember that there are different LPT-interface modes you can choose
in the BIOS setup. Maybe there's a problem with the mode you use?
Good luck!
thank You for Your answer! I've tried the LEDs. A LED connected to the
concerning pin of the LPT does go on and off, just as the windows
program dictates (on for 1 second, off for a minute).
To test the avr, I put a led to the output port (PB7) and decreased the
inactivity interval to a few seconds.
As long as I touched a wire with +5V to the input port (PB0) often
enough, nothing happened, when I didn't the LED would be on for about
1/10 of a second, just like it should.
Of course, I didn't try it for 20 minutes...
Does it have to be exactly +5V on the input port? I think the LPT of my
servers delivers something between 3V and 4V.
Do I have a problem with the 10k resistor? Should I activate the
internal pullup of the input instead?
Thank You,
Peter
I'd make sure that the parallel port is running in SPP mode, not EPP or
ECP.
Whether the 10k resistor is a problem or not can be checked with LED
debugger as well. Use another port pin and set it similar to your value
variable. Then you see what the AVR sees on the input-pin.
I don't see a problem in the program.
Thank You!
I will try changing the lpt settings.
Great idea with the value variable! Maybe that will help me!
Thank You,
Peter
webmaster@embdev.netContactAdvertising on EmbDev.net
