Hello All,
I am using YAGARTO 4.2.2 and using lpc2000 flash utility.
when i download the main.hex using lpc2000 following error occur;
"code in hex fileexceed flash limitations"
the cpu core i used :LPC2138
the linker script file i used below;
/* identify the Entry Point */
ENTRY(Reset_Handler)
MEMORY
flash : ORIGIN = 0x00000000, LENGTH = 128K /* free FLASH EPROM area
ram : ORIGIN = 0x40000000, LENGTH = 64K /* free RAM area */
/* define a global symbol _stack_end */
_stack_end = 0x4000FEDC;
/* now define the output sections */
SECTIONS
startup : { *(.startup)} >ram /* the startup code goes into FLASH
.text : /* collect all sections that should go into
FLASH after startup */
*(.text) /* all .text sections (code) */
*(.rodata) /* all .rodata sections (constants, strings,
etc.) */
*(.rodata*) /* all .rodata* sections (constants, strings,
etc.) */
*(.glue_7) /* all .glue_7 sections (no idea what these
are) */
*(.glue_7t) /* all .glue_7t sections (no idea what these
are) */
_etext = .; /* define a global symbol _etext just after
the last code byte */
} >ram /* put all the above into FLASH */
. = ALIGN(4); /* */
eh_frame :
KEEP (*(.eh_frame))
} >ram
.data : /* collect all initialized .data sections that
go into RAM */
_data = .; /* create a global symbol marking the start of
the .data section */
*(.data) /* all .data sections */
_edata = .; /* define a global symbol marking the end of
} >ram /* put all the above into RAM (but load the
LMA copy into FLASH) */
.bss : /* collect all uninitialized .bss sections that
go into RAM */
_bss_start = .; /* define a global symbol marking the start
of the .bss section */
*(.bss) /* all .bss sections */
} >ram /* put all the above in RAM (it will be cleared
in the startup code */
. = ALIGN(4); /* advance location counter to the next
32-bit boundary */
_bss_end = . ; /* define a global symbol marking the end of
the .bss section */
_end = .; /* define a global symbol marking the end of
application RAM */
PROVIDE (end = .);
awaiting for your answers
Regards
kamil
