Forum: ARM programming with GCC/GNU tools Problem with double precision floats in Yagarto
Author: Klaus Roy-Poulsen (Guest)
I'm having problem with double precision constants when using Yagarto
and associated libraries.
The problem seems to be that the lower 4 bytes are swapped with the
upper 4 bytes, compared to what the libraries and GDB expects.
A simple line of code
  double d = 10.0;
results in GDB reporting the value as 5.31664595E-315
whereas lines like:
  int i = 10;
  double d = i;
has the wanted result. Manually entering values in GDB results in values
GDB understands.
This is probably caused by some wrong or missing compiler option(s), but
I haven't figured out what I'm missing.
Currently the following CFLAGS are used:
CFLAGS= -g -O0 -mcpu=arm7tdmi -mthumb-interwork
And the following linker flags:
LFLAGS= -L $(YAGARTO_DIR)/lib/gcc/arm-elf/4.4.2/thumb/interwork
I have tried this with other/older version of Yagarto and the GNU tools,
but with same result.
Does anyone know which options to use and/or the options used to
generated the libraries?
Regards,
Klaus
The older ARM FPA used a strange cross-endian format that differs from
the more conventional format used by the VFP, but even without FP
hardware, the emulation will match the format of what it is emulating.
I would have thought that specifying -mcpu=arm7tdmi would have been
enough to specify the FP format used.
I have used hardware with VFP with an older release of WinARM and I had
to rebuild Newlib for VFP support (and GDB did not support VFP doubles),
so the default was at that time FPA and I do not expect that to have
changed.
However it may not hurt to experiment with the FP settings; try perhaps:
-mfpu=fpa -msoft-float, and if that does not make it all match up switch
to -mfpu=vfp -msoft-float.
Author: Klaus Roy-poulsen (krp)
Thank you for the input. -mfpu=fpa did the job.
Regards,
Klaus
webmaster@embdev.netContactAdvertising on EmbDev.net
