Forum: FPGA, VHDL & Verilog VHDL records
Author: Mark Gilson (Company: JHU Applied Physics Lab) (mwgilson)
I am trying to figure out if it is possible to assign all contents of a
record with a single statement or assign an output port as the entirety
of a record...for example:
Declarations & signal creation...etc...
type MY_RECORD is record
    A : std_logic;
    B : std_logic;
    C : std_logic_vector(5 downto 0);
    D : std_logic_vector(8 downto 0);
    E : std_logic_vector(14 downto 0);
  end record;
signal my_new_rec : MY_RECORD;
 process (SYSCLK, nRESET) is
  begin
    if nRESET = '0' then
      my_new_rec  <= (others => '0');
PORT_OUT  <= my_new_rec;
I've tried the .ALL (e.g. my_new_rec.ALL) but that is of course used
with variables.  Then I began to wonder if it might be possible to
complete this task by using variables as an intermediate?  If anyone has
any ideas please let me know.  In short, I'm trying to use records to
further subdivide a 32 bit std_logic_vector so I can do things like:
if(my_new_rec.A = '1') then
etc...
end if;
Please help.
Author: Duke Scarring (Guest)
With a default constant like this:
type MY_RECORD_t is record
    A : std_logic;
    B : std_logic;
end record;
constant default_my_record_c : my_record_t := (
  a => '0',
  b => '0',
  c => (others => '0'),
  d => (others => '0'),
  e => (others => '0')
signal my_new_rec : MY_RECORD_t;
  begin
      my_new_rec  <= default_my_record_c;
Duke
Author: Andreas Schwarz (andreas) (Admin) Flattr this
You can't use records to directly subdivide a vector. If you want to use
a record, you need to assign the components manually (or write a
function to do it). Another option is using aliases:
alias a is my_slv(5);
alias b is my_slv(4 downto 0);
if (a = '1') then
end if;
Duke, I think your method is a good solution to initialize a
record...thanks!
Andreas, I think this is one possible solution to parsing individual
parts of a vector...but in my scenario I will have tens of these records
of different types and I'm concerned these aliases could take up alot of
code space.  I think what I've found is that records are not the answer
to my problem.
To follow up, what are your suggestions to taking an input
std_logic_vector(31 downto 0) and also an output std_logic_vector(31
downto 0) and having the ability to dynamically "cast" these to
particular "formats" based on a given state.  In other words, maybe at a
given time each bit in the input std_logic_vector has a different
"name", but in another state the input is divided into an upper and
lower word.  instead of doing:
alias a is input(0);
alias b is input(1);
alias c is input(2);
alias a_a is input(31 downto 16);
alias a_b is input(15 downto 0);
I would have tens and tens if not hundreds of aliases if I did it this
way, which is why I tried using records until I found out there
limitations.  No other solutions?
  • [vhdl]VHDL code[/vhdl]
webmaster@embdev.netContactAdvertising on EmbDev.net
