Forum: ARM programming with GCC/GNU tools Can't compile *.s/*.asm files with avr-as
Author: Codi (Guest)
Posted on: 2010-01-13 00:17
Hello,
i have a problem. If i want to compile an assembler file with avr-as and
"m8def.inc" is included i can't compile because of these errors:
m8def.inc:139: Error: expected comma after "OCF1B"
m8def.inc:140: Error: expected comma after "OCF1A"
or
m8def.inc:449: Error: junk at end of line, first unrecognized character is`0'
m8def.inc:450: Error: expected comma after "INT1addr"
m8def.inc:450: Error: junk at end of line, first unrecognized character is`0'
and much more.
I guess it's because the "m8def.inc" file is written in AVR-Assembler
and not GNU-Assembler.
Now my question is:
How can i fix m8def.inc or better ;) is there already a pre defined file
like this for GNU-Assembler?
Thanks a lot :)
Author: mizch (Guest)
Posted on: 2010-01-13 00:31
You can't mix Atmel's def.inc files with GNU gas.  They are written for
a different kind of assembler.
Use #include <avr/io.h> to get the symbols for your processor.  They
will sometimes differ from what you're used to if you've been using AVR
assembler before, however.
Author: Oliver (Guest)
Posted on: 2010-01-13 09:56
If the whole file is written for Atmel assembler, you have to adapt not
only the includes to GNU, but also the rest of the programm. avr-as will
tell you, what ist doesn't like.
Oliver
Posted on: 2010-01-13 22:02
You need a different forum; this is an ARM related forum.
webmaster@embdev.netContactAdvertising on EmbDev.net
