Forum: ARM programming with GCC/GNU tools WinARM with Realview ICE
Author: Maverick Maverick (maverick202)
Posted on: 2010-01-08 09:53
I am a newbie to ARM development. I have a Realview ICE module and an
ARM7TDMI board. Does WinARM supports Realview ICE. If not are there any
better tools to work with Realview ICE.
Thanks in advance for your help.
M
Author: Tilo (Guest)
Posted on: 2010-01-08 10:57
Hi
Maybe you should post some more details. What kind of mcu is used on the
board?
WinARM should work with most ARM7 MCUs but at the moment it is a little
bit outdated. Maybe you should take a look at yagarto.
Cheers, Tilo
Posted on: 2010-01-08 14:56
It is always a good idea to seek support for a commercial product from
teh Vendor: http://www.arm.com/products/DevTools/RVIGDB.html
It appears that it will work with GDB so should work with WinARM (which
is a GNU toolchain).
It is perhaps obviously designed to work hand-in-glove with the RealView
compiler.  This is available from Keil, which is wholly owned by ARM.
http://www.keil.com/arm/mdk310.asp.  I would strongly recommend that you
use that if the budget allows.
Author: Spencer Oliver (ntfreak)
Posted on: 2010-01-09 16:00
Keil MDK does not directly support the RealICE, for RealICE you will
need ARM's RealView - not cheap.
Cheers
Spen
Posted on: 2010-01-09 16:45
My error.  In my experience if you buy the MDK it is generally easy to
blag a free ULINK2; you just have to have the cheek to ask!
Posted on: 2010-01-10 01:31
Thanks for the responses.
RVIGDB looks promising. I am exploring all the open source options. I
will update this forum once I find something.
webmaster@embdev.netContactAdvertising on EmbDev.net
