Forum: µC & Digital Electronics spi with GPS NEO-5Q (u-blox)
von moi (Guest)
Hello.
I would connect a gps to a PIC using SPI connection.
But i dont find in what do I have to send to the gps to receive te date.
When I send FF, I just receive random data who looks a bit like NMEA
data.
So i think i just don't send the write data to my gps.
Someone could help me ?
von David M. (md2k7)
NMEA does contain date + time information - why don't you just parse it
out?
Otherwise, just see the protocol specification at
http://www.u-blox.com/images/downloads/Product_Docs/u-blox5_Protocol_Specifications%28GPS.G5-X-07036%29.pdf
Yours,
David
von moi (Guest)
The problem is that I don't know how to get NMEA data with SPI.
The gps is the slave so it doesnt send the data alone.
That's why i think the master must send the good message to the gps.
And i already read the doc, but I didn't find it :s
Thank you.
"By default, all ports are configured for UBX and
NMEA protocol so in most cases, it’s not necessary to change the port
settings at all."
So just send 0xFF and read in data... (Altough I'm not sure that you
will get NMEA and not UBX data)
If you need to configure NMEA only, see page 97 and following,
especially field 'outProtoMask' in the document I've posted before.
"The baud rate clock provided by the master must not exceed 25kHz"
I'm not sure if this is a typo (not rather MHz?) or if they are really
telling you to use 25 kHz max., but I would give it a try.
von moi (Guest)
Okay!
In my doc (which is a bit different than yours (mine must be older))
there is : "The baud rate clock provided by the master must not exceed
250kHz".
And my baudrate is 166KHz.
So the problem may be here.
I'll try to reduce the baudrate under 25KHz.
von moi (Guest)
It works !
Thank you very much !!
