Forum: ARM programming with GCC/GNU tools WINARM and ARM9 runtime problem
Author: Mike Jubes (mjubes)
I have a test program which runs perfectly OK with an ARM7 device (NXP
LPC2138), but not with an ARM9 device (EP9302).
With ARM9 the program crashes -only- when some library functions are
called (marked (NO) below) It runs perfectly OK with others.
This sounds to me like some kind of library problem, but being rather
unfamiliar with GCC (I am more of an IAR person) I wouldn't know where
to start looking
Any ideas??  Thanks in advance
Lines that work/ don't work:
 a=atoi("20");    // yes
 p = malloc(100); // no
 sprintf(z,"hello");  // yes
 sprintf(z,"hello %d ",a);  // no
 puts("hello");       // no
 printf("hello");     // no
The programs were tested with an IAR compiler and both versions work.
"Cstartup.s" in both cases is set to leave the ARM in SYS mode (I have
also tried SVC) with interrupts disabled and plenty of stack space
allocated for all modes.
I have modified _write_r() in syscall.c to include output to the serial
port, In the ARM9 version the program never gets to this point. It's OK
with the ARM7 version
For the ARM9 project, I have tried various mods to the makefile i.e.
-mcpu=arm920 =arm9 etc to no effect.
I am using the latest WINARM 20060606 downloaded just a few days ago
(Dec 2009)
using arm-elf-gcc (GCC) 4.1.1 (WinARM)
Please take a close look into the generated assembly file and/or the
disassembly. The compiler might have already optimized "away" some
function-calls and replaced them with direct assignments during
compile-time for the functions marked "yes".
> to start looking
How did you find out "yes"?
At least linker-configuration are very different and startup-code needes
to be adapted for the GNU assembler.
For the libc-functions mentioned above the heap handling and must be
working. Did you verify that the "end" or "_end" symbol defined by the
linker and used by sbrk holds the address of the beginning of some free
RAM memory not used be data/bss/stack.
Did you check if a direct call to _write_r for your user-code sends a
character to the uart? Double-check if the addresses (start/end) for
data and bss are in RAM. I don't know the target-controller but for some
controllers RAM must be enabled esp. if it's external RAM. If you have a
debugger/JTAG-connection check if .data-copy, .bss zero-init and
stack-setup work as expected.
> It's OK
> (Dec 2009)
I suggest to use a more up-to-date binary-package. The tools in my
WinARM 6/06 are a little old. Codesourcery G++ lite, Yagarto and
DevkitARM include newer versions of the GNU toolchain.
Thanks for your quick reply, here are my comments:
I have looked at the .lss file ouput and followed the flow after
malloc() or printf() are called.
For example Malloc calls through: malloc, malloc_r, __malloc_lock,
_sbrk_r, __malloc_unlock
Printf calls through printf_r, vfprintf, vfprintf_r, localeconv,
__sinit,_swsetup, fflush, and a few others,
The .LSS output is a bit spartan and a bit tedious to follow, so I
didn't follow every bit, but noticed all calls are standard looking
branches, with the code actually present and nearby, i.e. nothing
untowards from just looking at the code first sight.
BTW: Optimisation is set to zero and the compiler is set to ARM mode
only (or I think it is)
I placed traps in between those lines. By traps I mean a simple macro
that sends a
byte to the serial output port, YOu can see how far the program gets
before it stops altogether (or decides to reset and start all over
again)
Thanks. I am aware of this. I have tested stack sizes and contents using
my own functions and they are all OK. BTW both ARM7 and ARM9 versions
work OK using my program which uses lots of my own calls, which include
interrupts and is over 64K long. Problems only arise when I include some
of the GCC library functions (and only on the ARM9 version)
This is what the symbol table shows:  I also printed the value of _end
in real time via the UART. (which showed the same)
00100000 D _data    Beginning of RAM
.....        My variables in between here
00103158 B fpga_phook    Last of my variables
0010315c A _bss_end_
00107200 A _end
00107200 B _stack
00107200 A end
This is the corresponding entry on the linker file
MEMORY
  ROM (rx) : ORIGIN = 0x00080000, LENGTH = 128k  /* program code loads
here */
  RAM (rw) : ORIGIN = 0x00100000, LENGTH = 512k  /* program RAM starts
here */
Yes it does. The same format is used in the ARM7 version which works OK.
Yes, double checked with the symbol table, all variables within the
range.
I am not that versed in GCC to be able to generate these tools without a
step by step idiot's guide. However I have downloaded the latest WinArm
version 20080331, I shall try that.
ARM9 generally requires more complex C runtime start up that ARM7 to
initialise the MMU, caches, and PLL.  Moreover ARM9 boards often use
external SDRAM; if this is the case the SDRAM controller must be
configured correctly before any code or data in external memory are
accessed - it will certainly crash otherwise, since it will read junk
from the memory.
Thanks, I am fully aware of this issue (we have been using this CPU chip
for quite a long time) All relevant MMU, PLL setups etc are implemented
in the startup module and work OK. So all memory partitions: cached,
buffered etc are initialised for the project needs before main() is
called. The program also works perfectly OK when compiled using the IAR
IDE.
Playing with the GCC linker script file I have managed to get the
program to work of sorts. It crashes on fewer functions by simply
allowing plenty of memory space between the various data, bss and stack
sections. So this is an area which we have to read the manual in more
detail.
Looking at your list of functions that fail, I would note two things;
1) Stdio formatted I/O functions require a relatively large amount of
stack space.  In my experience, around 4K minimum is required for all
threads that use formatted I/O + plus whatever the thread needs for its
own purposess.
2) malloc requires a correct implementation of _sbrk/_sbrk_r.  That is
to say not only must it return a valid address, but it must not 'grow'
the stack into any other memory regions such as the stack.  I doubt that
the ARM7 memory map is identical to the ARM9, and your last comment
would seem to indicate a memory map/allocation issue.  I suggest that
you place a break-point in sbrk, or somehow log all sbrk requests, to
see what addresses it providing and check them against the linker
generated map to see that they are not encroaching on other entities and
that the address is valid.
Clifford
Thanks for all that!
>stdio, around 4k minimum
With IAR I am using the "small" stdio model, which uses a lot less
memory!
>sbrk
I had a trap at sbrk, but during my tests, the program never got that
far!!
I finally managed to stop the program from crashing by allocating very
large chunks of RAM to the data and stack sections in the linker
description file.
I figure this is where the problem lies. So I have been spending time
studying the linker file format and its peculiar language. There must be
something causing an overlap there.
Haven't got very far with all the Christmas celebrations though. ):-)
Mike Jubes wrote:
>>sbrk
> far!!
I would expect sbrk to be invoked when dynamic memory allocation first
occurs.
>occurs.
Interesting.
When I followed the binary code in the .lss file the sbrk calls were way
down, after a few others. Admittedly, I didn't bother to check the paths
very thoroughly.
Thanks very much for your other comments anyway, as they triggered me
looking more deeply into the linker file.
I did not say that sbrk() was called first, but that it was called when
malloc() was first called; which is entirely different.  It is called
whenever the heap manager needs to extend the heap, which must happen at
least once on first allocation.
I too suspect that this is (at least in part) a linker script issue.
webmaster@embdev.netContactAdvertising on EmbDev.net
