Forum: µC & Digital Electronics CodeVision AVR: pointer type problem
Author: X- Rocka (x-rocka)
my CodeVision AVR is doing crazy things, but okay, more probable is that
I don't see my mistake...
I get the following error message (latest CV-version 2.04.4a, for
ATmega168P)
Error: D:\...\project_sercom.c(639), included from: project_0-1.c: function argument #1 of type 'char' is incompatible with required parameter of type 'char *'
// function call which the error refers to:
CRC_calc(*data_buf0, *datbuf0_cnt);
// the used global char array:
char data_buf0[DATA_BUF0_MAX];
// function:
void CRC_calc(char *data_buf, unsigned char *buf_cnt)
  unsigned char i = 0;
  unsigned char local_buf_cnt = 0;
  unsigned int ui_CRC = 0;
  char CRC_ASCII_byte[3] = { 0, 0, 0 };
  local_buf_cnt = *buf_cnt;
  // Calculate 16bit unsigned int CRC
  ui_CRC = ui_CRC ^ address;
  for ( i = 0; i < buf_cnt; i++ )
    ui_CRC = ui_CRC ^ *(data_buf + i);
    if ( ( 0x0001 && ui_CRC ) == 1 ) ui_CRC = ( 0x7FFF & ( ui_CRC >> 1 ) ) ^ 0xA001;
    else ui_CRC = 0x7FFF & ( ui_CRC >> 1 );
  // put CRC into 3 ASCIIs:
  CRC_ASCII_byte[0] = 0x40 | ( 0x000F & ( ui_CRC >> 12 ) );
  CRC_ASCII_byte[1] = 0x40 | ( 0x003F & ( ui_CRC >> 6 ) );
  CRC_ASCII_byte[2] = 0x40 | ( 0x003F & ui_CRC );
  // add the 3 CRC ASCIIs to buffer:
  for( i = 0; i < 3; i++ ) *(data_buf + local_buf_cnt + i) = CRC_ASCII_byte[i];
  *buf_cnt = local_buf_cnt + 3;
somewhere else in the code the pointers work perfectly, a string (char
array) is copied to a data buffer. no problems there.
please help!
X
Author: 12er Dude (Guest)
hello x,
please try this:
CRC_calc(data_buf0, *datbuf0_cnt);
or
CRC_calc(&data_buf0[0], *datbuf0_cnt);
the declaration of datbuf0_cnt is missing in your code.
Tschü Dude
Dude!
THANKS! ouch, WTF did I put the "*" into the function call...
Thanks, now it works!
Did I say thanks?!
X
webmaster@embdev.netContactAdvertising on EmbDev.net
