Forum: ARM programming with GCC/GNU tools Sample program WinArm with LPC2294
Author: Calvin Ho (gtpats)
Posted on: 2009-12-07 06:38
Hello,
I have worked with LPC2106 and winarm with success.
Now i would like to use Winarm with LPC-E2294 ( olimex) board.
Is there any sample program / test program(basic) which is used with
Winarm?
It would be helpful if someone can provide this.
cals.
Author: mthomas (Guest)
Posted on: 2009-12-08 13:34
I do not own a board with such a controller so there are no demos
included in the WinARM-package or available from the "WinARM-page" for
this controller. The LPC2294 ist similar to the LPC2106, so you could
start with code for an LPC2106, adjust the memory-sizes and
start-addresses in the Linker-Skipt, maybe add initialisations for the
memory-interface in the startup and verify if the initialistion-code for
interrupt-controller and clocking is compatible and modify if needed.
You may also try the code in TestProjekt_00.zip from
http://arm.hsz-t.ch/wiki/bin/view/Main/NeuesProjekt (page-content in
German)
I just found it through google, I have no further information on this.
You may also google for Ulrich Radig.He made a bootloader for LPC2294
which boots ucLinux but the Bootloader itself is for "bare metal" and
maybe you can reuse parts of the bootloader-code.
webmaster@embdev.netContactAdvertising on EmbDev.net
