Posted on: 2009-11-27 14:09
Hi everyone!! I am working with a board with a ARM11 processor (Freescale i.MX31). I have successfully cross-compiled the linux kernel 2.6.31 and it's already running on the board. In the board I have a LM73 temperature sensor connected via I2C. I already have the driver for the sensor (i.e. the lm73.c) and all the header files needed to cross-compile it. I just wanted to ask if someone could tell me how to cross-compile the driver so that I can transfer it to the board and then insert it as a module. I'm not an experienced linux user. I tried: root@ubuntu:~/../LM73# "Cross_compiler_path" -o LM73 LM73.c I get loads of errors that have nothing to do with my code but instead with header files that call other header files that call... Maybe I should write a Makefile, which I guess would consist only of a few simple lines..?? I would appreciate any kind of help. Thank you in advance.
