Forum: ARM programming with GCC/GNU tools Preventing GCC from optimizing out variable
Author: jrmymllr jrmymllr (jrmymllr)
I'm using CodeSourcery GCC for ARM and have this problem where when I
enable any level of optimization (1,2 or 3), this struct I have defined
as const is being optimized out.  It's a block of information that I
have deliberately put into a certain part of flash, so it's not accessed
by it's struct name, but by address.  GCC insists on removing it unless
I use -o0.  I have tried to fool it by assigning another variable this
struct's address, but it doesn't work.  Is there an easy way to simply
tell GCC not to optimize this away?
Author: Ernst (Guest)
You can try to use GCC _attributes_ to mark the structs as "used":
struct x y __attribute__((__used__));
http://gcc.gnu.org/onlinedocs/gcc/Variable-Attributes.html
Darn, didn't work.  No warning or errors, it still discards the struct.
There doesn't seem to be anything in the documentation for CS GCC about
this, however.
Author: Thomas Pircher (tpircher)
What about adding a pseudo-assembler instruction that uses the address
of the variable "my_struct"; something like:
__asm__ __volatile__("" :: "m" (my_struct));
Cool, that worked, thank you.
Author: Marcus Harnisch (Company: Doulos) (mharnisch)
What is "it"? Compiler or linker? The attribute only tells the compiler
that the variable is used, the linker can still toss it out. Check if
the variable is in the object file.
I am not a GNU expert, but it would appear that the ld-option
`--print-gc-sections' gives you a report about removed input sections.
Regards
Marcus
http://www.doulos.com/arm/
I don't know if the linker or compiler discarded it, but after adding
the _asm_ statement, it appears in the .map file and most importantly,
the code now works with optimization on.  The struct in question
contains strings that are displayed in a menu, so it's obvious when this
struct is missing.
webmaster@embdev.netContactAdvertising on EmbDev.net
