Forum: ARM programming with GCC/GNU tools flashing and debugging lpc2388 with eclipse, yagarto and openOCD really need help
Author: Thorsten F. (thorstenf)
I would like to programm and debug a nxp lpc2388 on a mcb2300 board.
Right now i am using following programms/drivers:
Windows XP SP3
Eclipse Galileo including Zylin CDT
Yagarto 4.4.2
openOCD 0.3.1 (installer Version from http://www.freddiechopin.info)
libusb win32
I am (more or less?) successful at compiling my sourcecode and
connecting openocd to the Olimex-arm-usb-ocd. I start opencd as an
externaltool (within eclipse) with the follwing arguments:
-f .../target/lpc2378.cfg
-f .../interface/olimex-arm-usb-ocd.cfg
So far the part that seems to work, if i connect Openocd i get the
following Output in the console:
Open On-Chip Debugger 0.3.1 (2009-11-13-16:13)
$URL$
For bug reports, read
  http://openocd.berlios.de/doc/doxygen/bugs.html
C:\Programme\OpenOCD\0.3.1\bin\openocd.exe: option requires an argument -- c
jtag_nsrst_delay: 200
jtag_ntrst_delay: 200
trst_and_srst srst_pulls_trst srst_gates_jtag trst_push_pull srst_open_drain
500 kHz
Info : clock speed 500 kHz
Info : JTAG tap: lpc2378.cpu tap/device found: 0x4f1f0f0f (mfg: 0x787, part: 0xf1f0, ver: 0x4)
Info : Embedded ICE version 7
Error: EmbeddedICE v7 handling might be broken
Except for the last Line everything looks ok. Unfortunately i have no
idea how to solve this problem, but actually do not think its my main
problem.
As soon as i start arm-elf-gdb using the following arguments:
target remote localhost:3333
monitor sleep 500
monitor poll
monitor flash probe 0
monitor flash info 0
monitor soft_reset_halt
monitor flash erase_sector 0 0 0
monitor flash write_image main.bin 0x0
monitor reset run
monitor sleep 500
symbol-file main.elf
info mem
thbreak main
continue
I see different "Versions" of behaviour. Unfortunately it just doesnt
work no matter which version i see. Most of the time it looks like this:
Warning: /cygdrive/D/workspace/merses/LCD/.dep: No such file or directory.
Warning: /cygdrive/D/workspace/merses/LCD: No such file or directory.
mi_cmd_break_watch: Missing <expression>
No registers.
0x00000000 in __lcd_print_from_thumb ()
monitor sleep 500
monitor poll
background polling: on
TAP: lpc2378.cpu (enabled)
target state: running
flash 'lpc2000' found at 0x00000000
#0 : lpc2000 at 0x00000000, size 0x0007d000, buswidth 0, chipwidth 0
  #  0: 0x00000000 (0x1000 4kB) protected
  #  1: 0x00001000 (0x1000 4kB) protected
  #  2: 0x00002000 (0x1000 4kB) protected
  #  3: 0x00003000 (0x1000 4kB) protected
  #  4: 0x00004000 (0x1000 4kB) protected
  #  5: 0x00005000 (0x1000 4kB) protected
  #  6: 0x00006000 (0x1000 4kB) protected
  #  7: 0x00007000 (0x1000 4kB) protected
  #  8: 0x00008000 (0x8000 32kB) protected
  #  9: 0x00010000 (0x8000 32kB) protected
  # 10: 0x00018000 (0x8000 32kB) protected
  # 11: 0x00020000 (0x8000 32kB) protected
  # 12: 0x00028000 (0x8000 32kB) protected
  # 13: 0x00030000 (0x8000 32kB) protected
  # 14: 0x00038000 (0x8000 32kB) protected
  # 15: 0x00040000 (0x8000 32kB) protected
  # 16: 0x00048000 (0x8000 32kB) protected
  # 17: 0x00050000 (0x8000 32kB) protected
  # 18: 0x00058000 (0x8000 32kB) protected
  # 19: 0x00060000 (0x8000 32kB) protected
  # 20: 0x00068000 (0x8000 32kB) protected
  # 21: 0x00070000 (0x8000 32kB) protected
  # 22: 0x00078000 (0x1000 4kB) protected
  # 23: 0x00079000 (0x1000 4kB) protected
  # 24: 0x0007a000 (0x1000 4kB) protected
  # 25: 0x0007b000 (0x1000 4kB) protected
  # 26: 0x0007c000 (0x1000 4kB) protected
lpc2000 flash driver variant: 1, clk: 4000kHz
requesting target halt and executing a soft reset
target state: halted
target halted in ARM state due to debug-request, current mode: Supervisor
cpsr: 0x000000d3 pc: 0x00000000
erased sectors 0 through 0 on flash bank 0 in 0.281250s
Verification will fail since checksum in image (0xea0000e4) to be written to flash is different from calculated vector checksum (0x26fedf8f).
To remove this warning modify build tools on developer PC to inject correct LPC vector checksum.
wrote 1216 byte from file main.bin in 0.453125s (2.620690 kb/s)
monitor reset run
monitor sleep 500
info mem
Using memory regions provided by the target.
Num Enb Low Addr   High Addr  Attrs
0   y    0x00000000 0x0007d000 flash blocksize 0x1000 nocache
1   y    0x0007d000 0x100000000 rw nocache
thbreak main
Hardware assisted breakpoint 1 at 0x412: file main.c, line 6.
continue
Allthough the flash seems to be protected, the Flash is erased
successfully und filled with my programm. Allthough i dont know how to
get rid of this wrong checksum.
Another Version contains this behaviour:
cpsr: 0x400000d3 pc: 0x00000000
memory write caused data abort (address: 0x40000000, size: 0x4, count: 0x2)
Write memory at address 0x40000000 failed (check work_area definition)
lpc2000 prepare sectors returned -307
failed erasing sectors 0 to 0 (-902)
wrote 1216 byte from file main.bin in 0.437500s (2.714286 kb/s)
Either way it just freezes at "continue" and i dont have a chance to do
anything.
I have tried to get this to work for a long time now. What confuses me
the most: with the same software and Configuration it works on another
pc. There i also have this "Error: EmbeddedICE v7 handling might be
broken" as well as the "wrong checksum" Error, but debugging perfectly
works.
Right now i am completely out of ideas and feeling really desperate. I
really hope that someone here can help me.
Thank you in advance
Author: Marcio Ribeiro (Guest)
I'm having same problems using olimex open ocd to program a lpc2368.
Could you tell me if you got you system working/programming?
Sds,
Marcio Ribeiro
webmaster@embdev.netContactAdvertising on EmbDev.net
