Forum: ARM programming with GCC/GNU tools Problem with strings
von Anoop B. (Company: erdciit) (anoop)
I developed a program to communicate with uart using arm9 (with
reference as James P Lynch's example demo_at91sam7_blink_flash.). I send
three string messages using uart and worked perfectly.. but when i
increased the number of messages the last portions of main function is
not working.. initial messages were displayed in the hyper terminal.. in
the Insight debugger there is no error. is there any special
considerations as the main function contains more strings and function
calls??
Anoop
von Clifford S. (clifford)
I am not sure how you could expect an answer without making the code
available. Your code is broken, and since there are any number of ways
you might have implemented serial I/O how are we supposed to know what
the problem could be?
How are you outputting the strings? If through printf() have you flushed
the buffer?  Is your UART interface polled or interrupt driven?  If it
is interrupt driven, how large is the output buffer?  What happens if
the buffer is full? Does it discard data or block?
If all you have observed is that not all the data arrives, it may not be
a serial output problem at all, the code may stopped working for some
other reason.  For example is your stack large enough?
I could go on asking dumb questions, but actually rather than wild
guesses how about some usable information from you?
Here is the code and the project file in progrmmers notepad...
629K download!?  Have you tried to narrow this down yourself using the
usual debug techniques?  It is a big ask to get someone to wade through
all that with no real idea what the problem is or its symptoms (you gave
a very vague description).
You do have a debugger right?
yes i debugged it.. but insight shows no error..
is there any problem in declaring a function as void function_name(void)
and int function_name(void) (..with return) in gcc? is there any
difference in the code generated??
