Forum: ARM programming with GCC/GNU tools LD error message
Author: Dan (Guest)
Hello,
I installed the newest yagarto. Downloaded the AT91bootstrap v1.14 from
the Atmel site:
http://www.atmel.com/dyn/products/tools_card.asp?t...
CD to C:\Bootstrap-v1.14\board\at91sam9g20\nandflash
make
I get the following error:
c:/yagarto/bin/../lib/gcc/arm-elf/4.4.2/../../../../arm-elf/bin/ld.exe:
section
.eh_frame [00200e64 -> 002010db] overlaps section .data [00200e64 ->
00200f27]
make: *** [nandflash_at91sam9g20ek] Error 1
What did I do wrong? How can I fix this?
Thank you,
Dan
You have omitted the part of the log that shows the linker invocation,
which would have been useful.
Are you sure that the linker script is correct for your target. You
appear to have two sections at the same location.
I believe that the eh_frame is related to C++ exception handling, but
are you using C++? Even if you are, are you using exception handling? If
not use the -fno-exceptions compiler option.
Author: Tom Swiedler (Guest)
If you are using a linker script (and you should be) you need to add a
section for the exception handlers. This can be in uninitialized RAM
memory.
  . = ALIGN(4);
  .eh_frame :
       KEEP (*(.eh_frame))
  } > ram
In the MEMORY section you should have a definition for the "ram" area
similar to the following:
  ram  : ORIGIN = 0x40000200, LENGTH = 32513
