Forum: µC & Digital Electronics WinAVR Accessing string in flash using pointer in struct in flash
von jerryr (Guest)
In spite of reading the previous contributions here, and the AVR
tutorial, I still have a problem to read a string in flash, using a
pointer in an array of structs, which is also in flash. The problam is
that the compiled program accesses the correct address, but in RAM. The
access to a function pointer is as expected.
I've been trying for a long time to fix this, but no success
The attached file is a complete source of an example.
The struct is:
typedef uint8_t (*PROCFNP)(char *);
typedef struct namefnpntr
{  PGM_P    namestr;
  PROCFNP  procfnp;
} NAMEFNPNTR;
The strings are put in flash with:
const char PROGMEM pgmPGALM[]   = "PGALM";
and a function dummy is:
uint8_t procPGALM(char *str)
  return 0;
The initialisation is like:
const NAMEFNPNTR namefntab[] PROGMEM =
   {  {pgmPGALM,   procPGALM},
We process the string with:
int8_t procGPS(char *chrp, NAMEFNPNTR *namefnp)
{  uint8_t i;
/* pointer to current struct in name/func table */
  void    *pgmp;
  PROCFNP  procfnpntr;
/* search the table for the sentence name, note that the table is
  in the program space
  for (i = 0; i < NAMEFNCNT; i++)
  { pgmp = (void *) pgm_read_word(&(namefnp[i].namestr[0]));
/* ***** Bug is in the above line **** */
    if (strcmp_P(&chrp[1], pgmp) != 0)    /* sentence name starts at 1
    {  pgmp = (void *) &namefnp[i].procfnp;
      procfnpntr =
        (PROCFNP) pgm_read_word(pgmp);
      return procfnpntr(chrp);  /* process the sentence */
  }  /* for table entry */
  return 0;
The bug is in the marked pgm_read_word()
The compiler produces LDD instructions to access the pointer to the
string, not LPM. See the lss file produced by the compiler, a snippet
from the disassembler is:
68:         { pgmp = (void *) pgm_read_word(&(namefnp[i].namestr[0]));
+0000008A:   81E8        LDD       R30,Y+0        Load indirect with
displacement
+0000008B:   81F9        LDD       R31,Y+1        Load indirect with
displacement
+0000008C:   9165        LPM       R22,Z+         Load program memory
and postincrement
+0000008D:   9174        LPM       R23,Z
This produces Z = 0x0000, not the contents of flash at the address
Thanks for reading this far,
Jerry
von mizch (Guest)
With
you access an element located in Ram, just as with any other variable
reference.  There's nothing in your argument to pgm_read_word() that
indicates it is to be fetched from flash.
Just as with any other element located in flash, you have to wrap your
reference into a pgm_read_word() call:
and make this expression the argument of your other program_read_word().
von jerryr (Guest)
Hello mizch,
    Thanks a lot, I wish I'd asked earlier! Now I understand that
pgm_read_word is the only thing which persuades it to read flash ROM
Best wishes, Jerry
