Forum: ARM programming with GCC/GNU tools Problem with pointers
von Anoop B. (Company: erdciit) (anoop)
The following is my make file.. which is used to print a string using
uart. i am getting the error 'undefined reference to memcpy' is there
any thing wrong with this make file.. The complete code is attached
here. i want to generate code for arm9
NAME    = sata
CC      = arm-elf-gcc
LD      = arm-elf-ld -v
AR      = arm-elf-ar
AS      = arm-elf-as
CP      = arm-elf-objcopy
OD    = arm-elf-objdump
CFLAGS  = -I./ -c -fno-common -O0 -g
AFLAGS  = -ahls -mapcs-32 -o start_up.o
LFLAGS  =  -Map main.map -Tmemory_map.cmd
CPFLAGS = -O ihex
ODFLAGS  = -x --syms
all: test
test: main.out
  @ echo "...copying"
  #$(CP) $(CPFLAGS) main.out main.hex
  $(CP) main.out main.elf
  $(OD) $(ODFLAGS) main.out > main.dmp
main.out: start_up.o main.o memory_map.cmd
  @ echo "..linking"
  $(LD) $(LFLAGS) -o main.out  start_up.o main.o
start_up.o: start_up.s
  @ echo ".assembling"
  $(AS) $(AFLAGS) start_up.s > start_up.lst
main.o: main.c
  @ echo ".compiling"
  $(CC) $(CFLAGS) main.c
#uart.o: uart.c
#  @ echo ".compiling"
#  $(CC) $(CFLAGS) uart.c
clean:
  -rm start_up.lst main.lst start_up.o main.o main.out main.hex main.map
main.dmp main.elf
von Rolf Magnus (Guest)
From the compiler or from the linker?
> is there any thing wrong with this make file..
You're using ld for linking instead of gcc. That means that all the
prerequisites for C are missing, like e.g. libc. You have to specify
those manually.
von Clifford S. (clifford)
Undefined reference is a linker error.
> those manually.
I think that answers your own question. ;) Good catch.
@ Anoop Babu
add -lgcc -lc to LFLAGS, you may also need to add -L<path> directives to
the appropriate library directories.  There are multiple versions of the
libraries and you need to link the ones that match the the architecture
the object files were compiled for.  This is why it may be easier to
drive the linker through the compiler driver and pass both CFLAGS and
LFLAGS so that the correct libraries are determined automatically.
thank you..
but i still have problems
can any one suggest the method to study WINARM..i.e books sites etc.. i
am just a beginner. i need to know how to write the startup code etc..
and want to build source code for arm9 IP Core...
Anoop Babu wrote:
> thank you..
WinARM is a package of open source tools from more than one project, but
primarily the GNU GCC toolchain.  The main components of the toolchain
are the compiler and the linker documented at
http://gcc.gnu.org/onlinedocs/ and
http://sourceware.org/binutils/docs-2.19/ld/index.html respectively.
> i am just a beginner. i need to know how to write the startup code etc..
You should start at the ARM-GCC development resources sticky thread at
the top of this forum. (http://embdev.net/topic/129986). Especially the
"Building bare-metal ARM with GNU" link.
Unfortunately most of the material including "Building bare-metal ARM
with GNU" relates to ARM7, often for microcontrollers with on-chip Flash
and SRAM.  An an ARM9 start-up is typically more complex; usually
requiring configuration of the MMU, caches, and setting up of an SDRAM
controller.  As an IP core, it will depend on what is included.
The "Insider's Guides" link has some ARM9 parts information, and the
SevensAndNines.com site has some ARM9 resources.
Also to take full advantage of the ARM9's speed (assuming you are
running at say > 60MHz - an ARM9 is typically around 200MHz, but it may
depend on what your IP core is deployed on), you would generally want to
run your code from RAM, which then requires the start-up code to copy
the code to RAM at start-up.  This can get quite complex, and to make
efficient use of Flash memory, you might store the image compressed, so
that the start-up must decompress to RAM.  If you are running the core
slower, then an ARM9 might not provide much over an ARM7 core.
It may be worth looking at an off-the-shelf bootloader.
Clifford
Thank u very much... hope that your support will be with me..
Anoop
