Forum: ARM programming with GCC/GNU tools Yagarto make Error
Author: Gary Embler (Company: Google Inc.) (gembler)
Using the latest Yagarto Tools and GNU ARM Toolchain, I get:
C:\Atmelprj\workspace\uc>make
C:\Program: C:\Program: No such file or directory
make: *** [Cstartup.o] Error 127
It appears I am using the correct make:
C:\Atmelprj\workspace\uc>make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-mingw32
Prior to upgrading to the latest Yagarto version, this error did not
appear.
The "C:\Program:" in the error message is suspicious. Could it be
truncating after the space in "C:\Program Files\..." ?
Any help on this is appreciated.
-Gary
Author: A. K. (prx)
Installing Unix/Linux related programs to a directory path containing
spaces is an easy way to get into all sorts of trouble. Either try to
find all places where paths are used without surrounding quotes, or
reinstall to a different place.
That's a good point. I've encountered this problem before. That's why I
suspected a problem with a space in the PATH. However, this was not a
problem on the earlier Yagarto version. I used the default installation
parameters which installed Yagarto under C:\Program Files.
As an experiment I uninstalled Yagarto and reinstalled directly under
C:\. This fixed the problem. mifi should change his installer script if
this is the way Yagarto now works.
Also, beware of the Yagarto Tools installation. It still has the NSIS
installer bug that corrupts the PATH if the PATH contains over 1K
characters.
-Gary
