Forum: ARM programming with GCC/GNU tools ARM GCC for both 7TDMI and Cortex-M3 possible ?
von Vaclav P. (vaclavpe)
Hello,
I plan to experiment with two ARM families - ARM7TDMI and Cortex-M3. Do
I need to compile (on Linux) gcc 4.3.4 twice and install one toolchain
for ARM7TDMI and second toolchain for Cortex-M3 ? Or can I have just
single toolchain for both families ?
I noticed that in some build scripts there is '-mcpu' parameter...
Should I build the toolchain for arm-elf, or for arm-eabi ?
Thank you in advance
Not needed, one with the appropriate settings will do.
There is also no need to build the toolchain yourself
(1) http://www.codesourcery.com/sgpp/lite/arm
(2) Downloads
(3) Target OS EABI
(4) GNU Linux installer
> Or can I have just single toolchain for both families ?
Yes.
The multilib settings are important.
I suggest to use eabi but from the user-side there are just a few
differences.
Hello Martin,
is there any disadvantage to use code sourcery toolchain ?
> Hello Martin,
I'm using the CS G++ ARM EABI lite package since several releases (on
Win32) to build code for different ARM7TDMI- and CM3-based controllers.
Until know it offers everything I need from a cross-toolchain so I
suspended building the tools myself. I have also recommended it to
clients and received no complains so far. The lite-version is not
limited in terms of code or binary size. It's basically the same as if
you would build bintutils, gcc, newlib and gdb yourself but you don't
need to twiddle with configuration-options and multilib-settings.
Codesourcery also offers limited free support for the lite-version in a
web-forum. If you do commercial work and may need full support at some
point you can buy it from CS. The Codesourcery-people know a lot about
the toolchain's source-code and I'm sure they can help if it's urgent
and you can't wait for help from the "community". I have never needed
support urgently so far but some clients demanded that code I created
for them must be buildable with tools for which they can get commercial
support, maybe you are in the same situation. Ok, enough "advertising"
for a free product from a company I do not work for. Just give it a try.
von Sebastian (Guest)
Hello,
is there any "free" compiler?
Is there a version of Free (GNU, BSD,,, licenced) GCC or something like
that?
Has anybody set up a free toolchein?
Sebastian
von mthomas (Guest)
>that?
gcc and binutils: GPL
newlib: http://sourceware.org/newlib/COPYING.NEWLIB
All souce-codes are available.
Several people/companies provide precompiles binaries of the
cross-toolchain. They are just for your convenience, so you don't have
to spend time to configure and build from source.
von Clifford S. (clifford)
> that?
Several listed in the resources sticky thread of this very forum:
http://embdev.net/topic/129986. There is even a link given to one in
this very thread that you hijacked to post you unrelated question!  You
are not looking very hard. It is not good practice to post your question
to someone else's thread.
