Forum: ARM programming with GCC/GNU tools Yagarto GCC and Cortex M3
Author: Tony Whitehall (tonywhitehall)
I am sorry, I am a newbie in GCC and ARM. I am trying to use LPC17xx
series of CPU and I am using the latest Yagarto build 4.4.1.
I search the internet and in this forum, and I don't seem to be able to
solve problem. I have read a few comment from Clifford Slocombe about
this subjects, and I have followed his suggestion, I still can't fixed
my problem.
I am writing a program that need floating point maths. So I have
included libgcc in my build. I keep  on receiving the following Error
message from the linker,"libgcc.a uses VFP whereas xxx.elf does not".
Clifford Slocombe said that in default GCC compile the code with
-mhard-float. Yet when I compile the code without -msoft-float , I still
receive the above message. If I compile with -mHard-float, I get
hard-float conflict with specified fpu.
My question is do I have to rebuild libgcc.a ? Clifford Slocombe seem to
suggest it is not necessary.
If I need to build libgcc.a, how do I do it ? I have installed minGW and
MSYS but I don't know how to use it with Yagarto.
Thank you in advance.
Best Regards to all
Tony
I suggest to "include" libm too (option -lm)
Verify that the target-options are also given for linking (-mthumb
-mcpu-cortex-m3), don't call the linker (*-ld) directly but use
compiler-frontend (*-gcc).
Should not be needed for your target.
I don't think so.
AFAIK Michael Fischer provides buildscripts. Cygwin might be a better
environment to build a toolchain. With the -nocygwin compiler-option
binaries can be generated which can work without cygwin-DLLs on any
MS-Windows system. But I expect building/updating the toolchain is not
needed.
Hi Martin,
Thank you for your response.
I am Sorry I didn't mention that I also include libc and Libm.
I am using  LD = $(GNUTOOLS)/arm-elf-gcc, I believe that is using the
compiler front.
After your response I include -mthumb and mcpu-cortex-m3 as part of the
linking option. Unfortunately, it make no difference.
It seem my best solution is to avoid using int64_t variables or make use
my own int64_t divide and mod , as the compiler uses link in libgcc for
these functions. Is this correct ?
>I don't think so.
>needed.
I have no experience in using cygwin. I am chicken out, so for the
moment I will try to avoid using libgcc or implement 64 bits divide and
mod.
Best Regards
Tony
Author: Tom (Guest)
Hi Toni,
I'm using yagarto too. I compile my program with options:
-mfpu=vfp -msoft-float
You should set the optimizing level to 0. (With level s I had no
floating point support: Beitrag "Yagarto printf und float funktioniert nicht richtig" )
Best Regards
Tom
Hi Tom,
You response hit the nail right on the head. The only option I didn't
try was -mfpu=vfp. When I compiled with -mfpu=vfp, I can now link with
libgcc.a
Thank you, Tom and Martin for your help.
Best Regard,
Tony
Author: Oliver B. (irq)
I'm having the same problem. Up to now I used a custom build gcc
toolchain, but maintaining it is too much an efford, so I decided to
switch to Yagarto.
My Makefile looks like this:
A_FLAGS = -mcpu=cortex-m3 -mthumb -Wa,-gdwarf-2
C_FLAGS = -mcpu=cortex-m3 -mthumb -O0 -gdwarf-2 \
          -mfpu=vfp -msoft-float \
          $(patsubst %,-I%,$(INC_DIRS)) -I. \
          -std=gnu99 \
          -ffunction-sections -fdata-sections \
          -Wall -Wextra -Wimplicit -Wcast-align -Wpointer-arith \
          -Wredundant-decls -Wshadow -Wcast-qual -Wcast-align -Wnested-externs \
          -Wno-cast-qual -Wno-missing-prototypes  -Wno-strict-prototypes -Wno-missing-declarations
L_FLAGS = -T stm32f10x_md.ld \
          -nostartfiles -Wl,--gc-sections \
          -lc -lm -lgcc \
As you can see, I tried -mfpu=vfp -msoft-float, but it did not work for
me. Maybe there is still something wrong.
Current Yagartos arm-elf-gcc was build without the configure option
"-with-float=soft", maybe that has something to do with it.
Is there anybody, who uses Yagarto for Cortex-M3 an can provide me his
Makefile?
Any other suggestions?
Kind regards, Oliver.
