Hi @ all, Im working with the student version of Modelsim, I have dowloaded the latest version (6.5b) and the licence and copied it to the root folder(C:\dev\Modeltech_pe_edu_6.5b). Now to the problem: Im using "vsim -voptargs=+acc work.tdm_bert_tb" as my run command. My only error report is: #Error loading design Due to the limited content of the error msg I have difficulties finding a solution. What have I already done: I have reinstalled Modelsim + licence with Administrator rights, tried running it with different -commands e.g. vsim -optargs work.tdm_bert_tb, vsim work.tdm_bert_tb (none). I only recieve the above mentoinened error. Any suggestions are welcome. Thanks in advance. Kel.
did you compile your designfiles/tb into the work lib using vlib and vcom?
hi, yes all files including the testbench are compiled.
In the most cases the error is shown many lines obove the "Error loading design" Message. Search the blue lines for "Fatal : ..." or so.
Hi supachris, thx for the hint but the only error line I recieve is the "#Error loading design" line and no other output. This is the fact that keeps me from investigating further.
I am getting the error "Error Load Design"(Modelsim student version). I have three modules and all are compiling without errors. However,the order for one of them (test bench) stays '0' in the left window. Now,while trying to run the three modules,I was getting the error which I have specified above.
If the topmodule isn't loadable, try the submodules one by one.
Make sure that your PDF student license is contained in the C:\Modeltech_pe_edu_10.0c' directory folder only( i.e. is not contained in any subfolders, the 'win32pe_edu' folder in particular!). I tried this before and it cured the #Error loading system# for me when it appeared! I hope this will cure some headaches aswell! Regards, Sentinel.
I just had the same error message myself
and this is how I fixed it
- Check your license is not in a sub folder especially 'win32pe_edu' in
the ModelSim directory
- and then check your "tb" design to see if your "module" and "uut" name
are one and the same for example mine was
module tb_ex1_gate();
and
ex1 uut
This led to the error "#Error loading design" because ModelSim could not
find it in the libraries, it should have been
and
ex1_gate uut
also when the this error appears you can find more detail when you
scroll up on the Transcript section
I hope all this helps I am using ModelSim PE Student Edition 10.0c
Thanks, Christian. Your input has helped me! Cheers..
