Forum: ARM programming with GCC/GNU tools OpenOCD load and debug fails sometimes
von Mike (Guest)
I'm trying to debug and flash my STM32 with OpenOCD/GDB.
I start openocd with the following command:
openocd -f openocd.cfg -c init
My Debug / Load configuration:
target extended-remote localhost:3333
monitor soft_reset_halt
set mem inaccessible-by-default off
load
compare-sections
monitor reset init
Load works  only  one attempt out of 5. The error message is just Load
failed...
Does anyone have a clue what the problem could be?
Thanks a lot!
Please show openocd.cfg.
You may also just try:
openocd -f interface/<yourinterface> -f target/stm32 init
which will use files from the "target library". I have used them in my
STM32 projects with success.
von Mike (Guest)
openocd.cfg:
interface ft2232
ft2232_vid_pid 0x0403 0x6010
ft2232_device_desc "Dual RS232 A"
ft2232_layout "oocdlink"
ft2232_latency 2
set BSTAPID 0x16410041
set WORKAREASIZE 0x5000
source  "C:/program files/openocd/target/stm32.cfg"
Openocd recognizes the target as stm32.
I use the yagarto toolchain with eclipse.
