Forum: ARM programming with GCC/GNU tools Help path yagarto and eclipse
von David V. (Company: itcr) (david_tec)
Hi!
I read the tutorial by j.lynch: "Using Open Source Tools for AT91SAM7S
Cross Development revision C" for to use the eclipse editor, but I have
a problem.
I installed all requirements, like the tutorial explain. When I try to
"build all", appear the follow message in the console window:
make -k all
arm-elf-as -mapcs-32  -o crt.o crt.s
arm-elf-gcc -mcpu=arm7tdmi -I./ -c -fno-common -O0 -g
-fomit-frame-pointer -Wcast-align    -c -o main.o main.c
arm-elf-gcc: CreateProcess: No such file or directory
make: *** [main.o] Error 1
-fomit-frame-pointer -Wcast-align    -c -o lowlevelinit.o lowlevelinit.c
make: *** [lowlevelinit.o] Error 1
make: Target `all' not remade because of errors.
I think the problem is the path, but I don't know like resolve the
situation.
I really appreciate the help.
Best Regards,
Open an input-prompt (cmd.exe) and type avr-elf-gcc --version
If you get a "...not found..." error check the path environment variable
As far as I know the Yagarto Installer adjusts the search-path so it
includes the path the the arm-elf-* binaries (Control
Panel->System->Extended->Environment Variables).
Thanks!
When I put the command avr-elf-gcc --version, it's the result:
"avr-elf-gcc" no se reconoce como un comando interno o externo,
programa o archivo por lotes ejecutable.
But, when I put the command arm-elf-gcc --version, it's the result:
arm-elf-gcc (GCC) 4.2.1
Copyright (C) 2007 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is
NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
However the is the same result in the console window in Eclipse Editor,
when I try to clean, and build all the project.
Best Regard,
