Forum: µC & Digital Electronics Ethernet cross 1:1
Author: Dirk (Guest)
I use ethernet with an AVR32. Connected to a switch with a 1:1 cabel and
direct to a network-card with a cross-over cabel. Is it possible to
connect two RJ45, wired 1:1 and cross-over, to a single MAC?
Of course only one connection can be used at a time, but whatever cable
you have you can connect to whatever port, switch/hub or netword-card.
Does the unused port must be terminated in some way?
Many thanks for your help
Author: Schrotty (Guest)
>Is it possible to
No! You cannot connect a RJ45-Jack or Cabel to a MAC. You can connect it
to a PHY which is connected to a MAC.
Modern ethernet PHY´s support auto-X-over functionality, which
automatically detects, whether a crossed oder a straight cable is
connected.
Thanks for your help.
The phy on my board do not auto-detect the wiring. Only modern
GigE-cards must have this feature. Old 100Mbit cards do not. OK, if I
wire two RJ45 with magnetics to my single phy, does the unused wires
will disturb the wires used? Both RJ45-connectors are still connected to
the single phy. Do I have to terminate the unused RJ45-connector?
It is only for the convenience of the user. Whatever cable he have and
to whatever he want to connect the uC, choosing the correct
RJ45-connector and done.
A lot of 100MBit PHYs support auto-x-over! but it´s not a "must", that´s
true..
You want to attach TWO magnetics and Jacks to ONE PHY?????
That´s (sorry) crap!
If you design your own PCB why don´t you use a simple 100MBit PHY with
auto-x-over and one Jack
(e.g.
http://www.micrel.com/page.do?page=product-info/fa... )
webmaster@embdev.netContactAdvertising on EmbDev.net
