hi i want to use pass transistor to design 4 to 1 switch and use vhdl hat somebody help me? thanks
> pass transistor
Can you specify what is meant by this term?
A bidirectional 4:1 multipexer?
when you say "i want to use pass transistor" this means, you already have such a device in your library, right? Then simply instantiate the component 4 times...
yes.the task is to design inputswitch use pass transistor instead of use
multipexer.
So you have a component "pass transistor"? Or do you have to describe such a "pass transistor"?
something like this?
case g0|g1|g2|g3 is when "1000" => q <= d0; when "0100" => q <= d1; when "0010" => q <= d2; when "0001" => q <= d3; when "0000" => q <= 'Z'; when others => null; -- FAILURE, q unpredictable! end case; |
Attached files:all fb can be 2and or 2nand .use switch to choice a inputsigal to fb and output too in same fb.
> something like this? The bidirectional behaviour is missing in this description :-/ > i have no component.so i have to do it So this looks like very low-level design. If you want to describe a bidirectional switch, most of the work will be the resolution function. Given the three ports A, B and C you must handle e.g. what happens if A = '1' while B = '0' and C = '1' (open) or what happens if A = '1' while B = '0' and C = '0' (closed)
A
C ----|
B
So such a pass transistor may look this way:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity PassTransistor is Port ( A : inout STD_LOGIC; B : inout STD_LOGIC; C : in STD_LOGIC); end PassTransistor; architecture Behavioral of PassTransistor is begin A <= 'Z' when (C='1') else '1' when (B='1' and C='0') else '0' when (B='0' and C='0') else 'X'; B <= 'Z' when (C='1') else '1' when (A='1' and C='0') else '0' when (A='0' and C='0') else 'X'; end Behavioral; |
In a simplified way by using the resolution function od std_logic you can write
A <= B when (C='0') else 'Z'; B <= A when (C='0') else 'Z'; |
> all fb can be 2and or 2nand .use switch to choice a inputsigal to fb and > output too in same fb. I urge you to get known to the terms and phrases used in your business. In your picture theres absolutely no bidirectional path, so its just a straight forward mux. Have a look at the code posted by berndl, thats a mux. But i don't clearly understand your picture. When you have 4 function outputs and afterwards a mux to 4 signals, which of the outputs must be routed to which signal. Can you scetch one or two signal paths in your picture?
What happens here with the other 6 inputs and 3 outputs? In your sketch you have 4 dual inputs, 4 function blocks and 4 outputs. This results in 64 possible routings, how can you handle this with a 2 bit input? The main problem to understand is why you have 4 outputs.
Lothar Miller schrieb: <What happens here with the other 6 inputs and 3 outputs? other 6 inputs and 3 outputs do nothing.because only one funktion block aviable with the switch
"Nothing" is no option. For shure they will do something ;-)
OK, lets give the kids some names:inputs functions outputs in0a fb0 out0 in0b in1a fb1 out1 in1b in2a fb2 out2 in2b in3a fb3 out3 in3b |
Are the only routing possibilities e.g. in0 - fb0 - out0 or in1 - fb1 - out1 ... Or can e.g. the in0 ever be routed to out3 through fb2?
Looks like homework... Maybe his teacher should help him or he should attend school regularly...
Lothar Miller schrieb: >> other 6 inputs and 3 outputs do nothing. > "Nothing" is no option. For shure they will do something ;-) > > OK, lets give the kids some names: >
> inputs functions outputs > in0a fb0 out0 > in0b > > in1a fb1 out1 > in1b > > in2a fb2 out2 > in2b > > in3a fb3 out3 > in3b > |
> Are the only routing possibilities e.g. in0 - fb0 - out0 > or in1 - fb1 - out1 ... inoa in0b fb0 out0 > Or can e.g. the in0 ever be routed to out3 through fb2? this can be in3a in3b fb1 out3 too
So it will be
inXa inXb fbY outX with (X=0..3, Y=0..3)
but never
inXa inXb fbY outZ with (X=0..3, Y=0..3, Z=0..3, Z/=X)
So how do you select one of the 4 input pairs to one of the 4 fb input
pairs (these are 4x4=16 possible ways) with only 2 bits?
Dong Wang, probably you could just explain, what you really want to do with this piece of hardware. * What type of signals are the inputs? Analogue, LVDS, just digital '0' and '1', serial data? Or what else? * What is expected as output? * And what should the 2-bit counter do? * And, most important, what should this circuit really do? Otherwise I'll stop reading deep in my coffee-mug...
Nichts gegen Tipps von Hobbyist zu Hobbxist, oder von Fachmann zu Fachmann, aber schon mal gedacht dass man sich damit schwer schlagbare Konkurrenz schafft. Es heisst ja Erfahrungsaus-t-a-u-s-c-h , wobei dieser Anfrager fachlich nicht viel zum tauschen hat. MfG I am not against Exchanging KnowHow between hobbyist or from Expert to another. But have you ever given ist a thought, thats that makes a hard to beaten competition. It's called ex-C-H-A-N-G-E, but this applicant has nothing to swap. Best regards
> ... dass man sich damit schwer schlagbare Konkurrenz schafft.
Glaube ich nicht, bzw. macht mir keine Sorge ;-)
Lothar Miller schrieb: >> other 6 inputs and 3 outputs do nothing. I think it should work like this: - One of the "2-inputs" on the left should be switched to the input of ALL function blocks in the middle (the rest three left inputs are ignored) - One of the FB outputs schould then be selected as output (the rest are High-Z, don't cares or holding the last output) Probably for a testing devices/input one after the other with just needing the 4 Input blocks once. Grashalmlängenkontrollminister schrieb: > Looks like homework... I agree with that especially the terminus 'pass transistor' more sounds like he should construct a complex-cmos-device than a VHDL code... Because when my assumption is true, this task could be more easily be acomplished by a pipeline than by such a strange "pass-transistor-design"...
to Läubi .. you are right.i have figured it out. thanks all your help
