Forum: ARM programming with GCC/GNU tools #if with no expression
Author: Gast (Guest)
I've got the following code fragment and getting the error as indicated.
I have no clue why it doesn't work, it seems to be alright for me...
Google didn't help either, just tons of kernel compilation bug reports
etc. but no solution. Any help is appreciated!
#define XYZ
#define WITHB
#ifdef XYZ
 #ifdef WITHA
        if (count < 1000) {
            save[count] = (short)IP;
            count++;
 #elif WITHB                           //<-- ERROR: #if with no expression
        if (count < 1000) {
            save[count] = temp;
            count++;
 #endif
#endif
Author: Guest (Guest)
never heard of something called "elif". I just know "elsif". Try that
Author: Rolf Magnus (Guest)
#elif  is not the same as a combination of #else and #ifdef, but rather
#else and #if. And #if requires an expression, which is missing if the
macro isn't defined.
Author: Ralf (Guest)
This expression equals to
 #else if WITHB == TRUE                          //<-- ERROR: #if with no expression
but since you only defined WITHB (without a value) it is expanded to 0,
which equals FALSE.
Try either to define WITHB with a value or change your if-statement as
follows:
 #else ifdef WITHB
Regards,
Ralf
> ... which is missing if the macro isn't defined.
Actually I meant "which is missing if the maco is defined, but empty".
If it's not defined, that's ok.
So try:
#define WITHB 1
Author: Stefan Ernst (sternst)
#elif defined(WITHB)
Wow, thats quick :-)
I tried #elsif before, but that resulted in some weired behaviour.
Thanks to Ralf and Rolf's solution it works as intended now!
Thanks very much for your help!
#define WITHB 1
Rolf makes a good point, but a better solution is to use the improved
preprocessor syntax introduced in ANSI C in 1989! Despite its 20 year
history, this K&R syntax is still prevalent; I have no idea why. This is
what you need (already suggested by Stefan Ernst rather more succinctly
and without the rant):
#define XYZ
#define WITHB
#if defined XYZ
 #if defined WITHA
        if (count < 1000) {
            count++;
 #elif defined WITHB
        if (count < 1000) {
            save[count] = temp;
            count++;
 #endif
#endif
That way you never need to assign a value to the macros; their mere
existence is enough.
I have no idea what "Guest" was talking about; in what language is
#elsif valid I wonder!? Certainly non-standard, and not documented in
the GNU C preprocessor:
http://gcc.gnu.org/onlinedocs/cpp/Index-of-Directi...
