Forum: ARM programming with GCC/GNU tools Beginner programmer/debugger recommendations?
von Luke Taylor (Guest)
Hey everyone,
I'd like to pick your brains and get some recommendations on which
programmer/debugger I should get (as an amateur hobbyist with a low
budget and some experience in C/assembler for PICs).
Recommended books for a noob?
Recommended Programmer?
Is this one better:
http://www.sparkfun.com/commerce/product_info.php?products_id=7834
than this one:
http://www.sparkfun.com/commerce/product_info.php?products_id=8278
Recommended arm processor?
http://www.sparkfun.com/commerce/product_info.php?products_id=520
Is this compatible with the above programmers?
I realize I have asked a lot so answers to any one of my questions would
be greatly appreciated. Thanks a lot community!
von Andreas S. (andreas) (Admin)
The LPC2xxx series is a good choice for a beginner, because the
controllers can be programmed with the built-in serial bootloader over a
RS232 cable or a standard RS232-USB-Adapter. You only need a JTAG
adapter for debugging (stepping though the code, reading memory). So if
you want to save money, you can just get the controller (or better, a
board with the controller), and buy a JTAG adapter later. If you buy
one, you can get the cheaper version, it works just as well as the more
expensive one, but is missing the built-in USB-RS232 converter. Both
versions are compatible to the LPC2xxx (and all other ARM controllers
with a standard JTAG port).
I don't have any book recommendations, but you can find a few links to
introductions and example programs here:
http://embdev.net/topic/129986#new
von Freddie L. (Company: None) (cap45)
Hi Luke,
Here is a better tool that works right out of the box.  All you need to
do is add a Debugger like Eclipse or Insight or just use a command line
GDB server. You will be up and running in 10 minutes.  They have a
"Non-Commercial" version for $149.
http://www.segger-us.com/jlinkncubundle.htm
I found this tool MUCH MUCH more reliable than the Olimex tools.
Just a minor update...
"command line GDB server" should have said "command line GDB".  The GDB
Server comes with the Segger J-Link Tool already.  The command line GDB
usually comes with the compiler (WinARM, YAGARTO, CodeSourcery, etc...).
Freddie Leaf wrote:
> Hi Luke,
