Forum: ARM programming with GCC/GNU tools yagarto and serial i/o
Author: Carl (Guest)
I'm trying to compile some Linux ARM code using Yagarto, but I'm running
into difficulties when it comes to configuring serial i/o using the
'termios' structure. Yagarto doesn't recognize any serial i/o options as
it does when it's compiled under Linux using the GNU-ARM compiler:
serial.c: In function 'serial_speed':
serial.c:92: error: invalid application of 'sizeof' to incomplete type
'struct termios'
serial.c:92: warning: left-hand operand of comma expression has no
effect
serial.c:94: error: invalid use of undefined type 'struct termios'
serial.c:94: error: 'B9600' undeclared (first use in this function)
serial.c:94: error: (Each undeclared identifier is reported only once
serial.c:94: error: for each function it appears in.)
serial.c:94: error: 'CS8' undeclared (first use in this function)
serial.c:94: error: 'CREAD' undeclared (first use in this function)
serial.c:94: error: 'CLOCAL' undeclared (first use in this function)
serial.c:95: error: invalid use of undefined type 'struct termios'
serial.c:95: error: 'IGNPAR' undeclared (first use in this function)
serial.c:96: error: invalid use of undefined type 'struct termios'
serial.c:101: warning: implicit declaration of function 'tcflush'
I have include the header file 'termios.h', but I don't think it's
finding the right one. The ones in Yagarto are vastly different than the
ones in Linux.
Author: Jupp (Guest)
I am not sure if this is possible with yagarto. Yagarto is afaik for
bare metal systems only for it uses the EABI link format.
Have you tried another toolchain like code sourcery for linux targets?
http://www.codesourcery.com/sgpp/lite/arm/portal/s...
The lite edition is free like yargarto.
Thanks I'll try it.
I also noticed that Yagarto doesn't contain support for networking. I
can't find socket.h anywhere. Is this intentional, or will support for
networking be a future addition?
/carl
Author: Andreas Schwarz (andreas) (Admin) Flattr this
Yagarto is a toolchain for "bare metal" software. It only includes the
standard library, no socket.h or any other POSIX stuff. If you want to
run programs that use POSIX or Linux APIs, you need to run an operating
system like eCOS, RTEMS or Linux, each of which require a special
toolchain. If you only want to do networking, there are some simpler
options like uIP, lwIP.
