Forum: FPGA, VHDL & Verilog Concept on Blocking assignment and always
Author: Jason Kee (Company: Myreka) (jasonkee111)
i read an article about blocking assignment.
module fbosc1 (y1, y2, clk, rst);
output y1, y2;
input clk, rst;
reg y1, y2;
always @(posedge clk or posedge rst)
if (rst) y1 = 0; // reset
else y1 = y2;
if (rst) y2 = 1; // preset
else y2 = y1;
endmodule
Case1
If the first always block executes first after a reset, both y1 and y2
will take on the value of 1.
Case2
 If the second always block executes first after a reset, both y1 and y2
will take on the value 0.
Question:
1.  How is the flow for above case in terms of always block and blocking
assignment?
2.  if reset = 1, y1=0 and y2=1, isn't it?  i don understand the
explaination above.  So, Try to explain in details.
Thanks a lot
Author: berndl (Guest)
>else y1 = y2;
>else y2 = y1;
hi,
you will only have a problem if your asynchronous reset violates the
setup/hold time of the flip-flops. Then the output of y1/y2 is
unpredictable. If you change the reset to a synchronous type, it's much
easier and clear what will happen.
And it get's even more clear when you write this code into one single
process.
Or am I completely wrong? :o)
Author: Gast (Guest)
Something to read on blocking vs. nonblocking:
http://www.sunburst-design.com/papers/CummingsSNUG...
On the other hand: Why not try making your homework yourself?
The problem stated above is the example i grab from that article.  I
don't understand the explaination.  So, i ask in forum.  Thanks
1:
"According to the IEEE Verilog Standard, the two always blocks can be
scheduled in any order. If the first always block executes first after a
reset, both y1 and y2 will take on the value of 1. If the second always
block executes first after a reset, both y1 and y2 will take on the
value 0. This clearly represents a Verilog race condition." (Cummings)
Simulation of HDL runs in time steps. Time steps are triggered by
events, such as posedge clk or posedge rst in this case. Within a time
step, all your code is evaluated. If the evaluation of the code
generates a changed status of any RHS statement, all code is evaluated
again with the new RHS value. This is done until there are no RHS
changes, then the simulation time is advanced to the next event.
Blocking assingments propagate the value instantly, i.e. within a
timestep. So once the simulator arrives at the second process, the input
is changed already.
Both processes are scheduled to run on the same simulator time step (the
step where "posedge clk").
Now let's consider the first process being run first:
y1 = y2 (which is 1 at first posedge clk after release of rst)
Next step for the sim would be to evaluate the second process (still,
time in the simulator has not advanced!)
y2 = y1 (which is now, thanks to blocking assignment already changed to
1)
As the simulator does not see any changes on the RHS assignments to y1
and y2 anymore, the timestep is considered done and time advances to the
next event.
Same goes if the second process runs first:
y2 = y1 (which is 0 after rst)
Now again thanks to blocking assignments, y2 is already changed to 0:
y1 = y2
In this case you end up with both y1 and y2 being 0.
So as a bottomline: The result clearly depends on which process is
evaluated first (in a naturally sequential simulation of the HDL). As it
is not defined in the verilog standard which one is to be evaluated
first, the fastest one wins. And that's called a race condition.
2:
While rst you don't have a problem. y1 and y2 are perfectly defined.
Problems start once you release rst.
N.B.: If you want to synthesise that example to hardware, the hardware
would behave like the designer probably intended it to do. In the
simulator it would however not show the same behaviour as in hardware.
I think the easiest conclusion would be: Avoid using blocking
assignments until you really know what you are doing. For my part, I
am only using non-blocking assignments simply because it's less
error-prone.
Author: James M (Guest)
I think all the replies are missing the point; this example and
explanation are not intended to be synthesizable RTL but to demonstrate
blocking statements.
As Gast states above, the simulation is done in time slots.
A blocking statement says assign the right hand value to the left hand
side and don't do anything else until the left hand variable has been
updated.  Thus anything that uses the left hand variable subsequently
will have the new value after.
When reset is asserted, both elements are preset; y1=0, y2=1.
The only time they will change will be after reset is deasserted, and on
the rising edge of the clock.
At that point, there are two cases as described.  In case one the
statment y1 = y2 is executed first.  y1 takes the reset value of y2, 1
then the block is released and the other statement executes, y2=y1.
Since y1 has been updated y2 will take this new y1 value, i.e. 1.
If they were non-blocking statements, the both y1 and y2 would take on
the old value of the other; i y1 would = 1 (reset value of y2) and y2
would be 0 (reset value of y1).
The effect would be y1 and y2 would always be opposite logic levels and
they would both toggle on each clock.
  • [vhdl]VHDL code[/vhdl]
webmaster@embdev.netContactAdvertising on EmbDev.net
