Forum: µC & Digital Electronics Stretch 25ns TTL pulse to >100ns
von Photons in Biochemistry (Guest)
Dear ladies and gentlemen,
we are trying to read out a single photon counting module that sends us
TTL pulses of a width of 25ns.
Our counting module can count up to 5MHz, but only at a pulse width of
100ns.
We want to operate the detector at much lower count rates ~10kHz, so
stretching the TTL pulse we would not loose too much information.
In the biochemistry departement, we do not have a lot of knowledge in
electronics.
Is there a "simple" way to reach our goal?
We are very much looking foreward to your replies.
von ::: (Guest)
monoflop ?
Thank you for the reply.
I just tried to learn about "monoflop" by reading the wikipedia article
and also found a monoflop e.g. on reichelt.de.
But that means I will actually have to build a circuit on my own,
doesn't it?
I am not familiar with electronics.
von MWS (Guest)
@Photons,
a fast Google search got me the Berkeley Nucleonics Corporation website,
the model 575 would likely suit your requirements, could also be it's
overkill. You may want to check.
In contrary, to make your unit work as little as one diode, two
resistors and one capacitor could do the trick. Depends on the counter
input circuitry.
But even for that you'd need somebody in your institute to try, test,
and set it up for you, as it would be no out of the box solution. And if
you have not even a slight idea about electronics, there's high risk
you'll fail.
von Reinhard Kern (Guest)
Hello,
maybe, but before you should specify your detector pulse: length 25 ns
ok, but what is inactive voltage level, active voltage level, source
impedance (50 Ohm Coax?)?
Probably you could use a triggerable high speed pulse generator, trigger
it with the 25 ns pulse and switch the output to 100 ns pulse legth -
but this is total overkill, sensefull only if you have one.
regards Reinhard
von faustian (Guest)
Check out the 74LS221 or 74HCT221 ICs, which should be available at a
low price, around 50 cents apiece.
In case you are unfamiliar with 74xx ICs: Always put a small ceramic
(around 100nF) and an electrolytic capacitor (around 100uF) across the
VCC and GND pins, using the shortest wiring length possible between IC
and ceramic capacitor. Do not ever leave any input open circuit, always
connect to VCC (optionally via a 5-10K resistor. In practice, with a
clean 5V supply you should be fine without), GND or an active output of
another IC. Never directly connect outputs together (unless the
datasheet explicitly allows so), never connect an output directly to
VCC.74f221
@ Reinhard
Thanks for the input:
The TTL pulses are ~0V low, ~3V high (as estimated from an
oscilloscope).
I can't afford overkill.
I read more about this monoflop. If I can get someone from one of the
workshops to build it this might actually do the trick.
Greetings from Zurich
von ::: (Guest)
In not too familiar with this TTL Family anymore, but I guess a 74LS123
should do.
Greetings from Zuerich too.
von MWS (Guest)
As you can't afford overkill, you may try the cheap side :D
Counter needs high input resistance for that.
von schon (Guest)
What values should he use with this? The decay constant should be
T=2Pi*R*C, right? Meaning that if he wants 100 ns for a 1 M Resistor he
needs such a small cap that the stray capacitance will already be too
much...
