Forum: ARM programming with GCC/GNU tools Lost the return value of assembly code after optimization
von Tim C. (hardwing)
Hello,
I made a program mixed with C and asm by GCC.  It works fine if no
optimization but run away after optimization with switch "-Os".
After traced code, I found asm code didn't return r0 value back to C
routine....
**********My C code**********
  volatile struct iphdr *ip_hdr;
  ip_hdr->check = ip_fast_csum((unsigned char *)ip_hdr,ip_hdr->ihl);
**********My ASM code**********
    .global  ip_fast_csum
    .text
ip_fast_csum:
    ldr    r3, [r0], #4
    ldr    r4, [r0], #4
    sub    r1, r1, #5
    adds  r3, r3, r4
    ldr    r4, [r0], #4
    adcs  r3, r3, r4
    ldr    r4, [r0], #4
    adcs  r3, r3, r4
_l:    ldr    r4, [r0], #4
    adcs  r3, r3, r4
    tst    r1, #15
    subne  r1, r1, #1
    bne    _l
    adc    r3, r3, #0
    adds  r3, r3, r3, lsl #16
    addcs  r3, r3, #0x10000
    mvn    r3, r3
    mov    r3, r3, lsr #16
    mov    r0,  r3
    mov    pc, lr
I found the result of ip_hdr->check always zero although the content of
r0 is correct at the end of assembly?
How can I control the optimization to keep r0 return correctly to
ip_hdr->check?
BRs.
Tim
von (prx) A. K. (prx)
Either
-fdo-what-i-mean-not-what-i-say
or
-favoid-all-bugs
For more, you should provide a testcase which can be used and tested by
readers.
And btw: If speed is premium, drop the count and compare R0 to the final
address (TEQ).
You violated the procedure calling standard. R4 must be preserved across
function calls. See
http://infocenter.arm.com/help/topic/com.arm.doc.ihi0042a/IHI0042A_aapcs.pdf.
Ah....
You are right.  It is my mistake.  It should be R2 instead of R4.  It is
running well now.  The problem actually didn't come from
optimization.... just because I was lucky at "-O0".
You are helpful and thanks.
BRs.
Tim.
von Clifford S. (clifford)
> ip_hdr->check?
That was wrong-thinking there. If your code breaks when it is optimised,
it is most likely that your code was flawed in any case, but that
without optimisation the error was benign.
Th optimiser may reasonably expect your code to comply with the calling
convention and will then use available resources with that assumption.
von Jim K. (ancaritha)
A. K. wrote:
> Either
> or
> -favoid-all-bugs
Best compiler flags ever.  I use them in just about every project I work
on :P
