Forum: ARM programming with GCC/GNU tools Problem in arm-elf-gcc running in the Linux PC
von Tim C. (hardwing)
Hello,
I started to install arm cross-complier in my linux pc (ubuntu8.04).
Then, download the toolchain for linux from here.
http://embdev.net/articles/ARM_GCC_toolchain_for_Linux_and_Mac_OS_X
and add the following in the /etc/profile
PATH=/usr/local/arm/bin:$PATH
export PATH
But after make the file, I found the following error.
arm-elf-gcc -x assembler-with-cpp -c -mcpu=arm7tdmi -g -gdwarf-2
-Wa,-amhls=src/initcpu.lst   src/initcpu.s -o src/initcpu.o
arm-elf-gcc: error trying to exec 'cc1': execvp: No such file or
directory
make: *** [src/initcpu.o] Error 1
Can someone help?
Tim
von Stefan B. (forscher)
Tim,
the executable cc1 resides in the folder
.../arm/libexec/gcc/arm-elf/4.1.0/    (I used 4.1.0)
I had this problem some times ago, it is a problem with the path.
Maybe it helps to place a copy of this cc1 in the folder
/usr/local/arm/bin
I hope this will work ...
Stefan
Stefan,
It works! Thanks.
But seems I face another problem to link up syscalls.c.  I need to study
more.
Anyway, thank you very much.
Tim.
