Forum: ARM programming with GCC/GNU tools Why Does newlib for yagarto use stubs?
Author: Richard Shadbolt (Company: Home Use) (shadders)
I have been using the Yagarto tools to program the AT91SAM7S embedded
Evaluation Kit.
From version 4.3.2 to version 4.3.3 they changed the newlib as folows :
!!! This version of YAGARTO was built to support newlib with reentrant
stubs !!!
I have a few questions on this :
1. Why did they do this ?.
2. Why use reentrant stubs which seem to only interface to a piece of
code which you want to use. Why not use the procedure in its entirity ??
3. I think i can answer question 2 but not sure - it is to stop multiple
copies of the functions sprintf for example being created in the
program, and hence reduces overhead. Can anyone confirm that i am
correct in this ? Thanks.
4. If they were going to use stubs for reentrant code - why did they
state :
To make your life easier, an example "syscalls.c" can be find here:
http://www.yagarto.de/download/yagarto/syscalls.c
Where they have provided EXAMPLE syscalls.c. Why not just provide the
definitive code for all to use without having to worry about it
themselves ???
From what i can determine, you need to be very proficient in C and the
details of how the compiler works and the interdependencies of the
libraries.
I think that a novice in this area would be confused as i am.
Regards,
Richard.
Author: Tilo Lutz (Guest)
Sure but thats the way programming works.
yagarto is a free toolchain. If you want more you will have to buy a
comercial toolchain.
/EDIT
It's on to you to change this if you want.
Hi Tilo,
Thanks for the reply.
I just wondered why they did what they did in 4.3.3 and yet 4.3.2 was
OK.
The sprintf function works on the embedded design, so i am perhaps
confused at the mention of stubs thinking that the sprintf function
would not work and i had to provide some interfacing.
Regards,
Richard.
I haven't used newlib very often because it makes no sense to use it in
small uC projects.
Afaik the reentrant versions are needed to make newlib thread-safe.
Most of your questions wer probably answerd on teh other thread you
tacked your question onto: http://embdev.net/topic/133927
The stubs are implemented to map teh library to your hardware.
C has a global errno variable. In modern implementation it is not really
a variable but a macro. In multithreaded code you need an errno value
for each thread, otherwise you might test its value in one thread when
it was set by another. The renetrant stubd allow you to inplement the
necessary code for thread local storage. That's one reason.
That is nothing to do with it.
> state :
> themselves ???
Because not everyone's hardware is the same. Most embedded systems use
proprietary hardware, even if they were initially developed on an
evaluiation or dev board. You need to be able to adapt the library to
work on any platform.
> libraries.
Maybe. Better documentation for Newlib would help, with some more
realistic examples for different situations.
If you are using off-the-shelf hardware and the work has already been
done, you have it easy. The first time I used Newlib was on entirely
in-house hardware for a ARM9 microcontroller that had no existing BSP
package.
Clifford
Author: Mini Papatt (Guest)
hi Richards,
i try to build my project with your syscalls file but when i have this
error
[c]-IC:\PROGRA~1\yagarto\arm-none-eabi\include -I./inc src/syscalls.c -o
src/syscalls.o
src/syscalls.c:12:19: fatal error: uart0.h: No such file or directory
compilation terminated.
make: *** [src/syscalls.o] Error 1[c]
Can you tell me where i could find this header file?? because i don't
find it in the include folder of Yagarto
Best Regards
Mini,
Author: Martin Thomas (Guest)
Please do not post in such an old thread. Next time open a new thread
with your question.
The answer to your question: there are different methods to implement
syscalls. The easiest method is to hard-code the input and output to the
underlaying hardware directly into the syscall-function. Since the
underlaying hardware is system-specific you have to look what functions
the syscall-code expects (something like uart0putc oder uart0getc) and
implement these functions so they access the uart of your controller. I
don't know the syscall-implementations which came with Yagarto but as
far as I know Michael Fischer provides example Applications for some
controllers which you can use as template to adapt the code to your
target.
An alternative method is to use a set of functions-pointers so the
syscall-code itself is not hard-bound with a single device like uart0.
An example how to do this can be found in the newlib-lpc code which is
rather old but shows the basic idea.
