Forum: ARM programming with GCC/GNU tools long calls generating in gcc
von Bartłomiej Kubica (Guest)
hi,
I'm confused with way how long calls are generated when compiling some
example code
#pragma long_calls
void *reserve_ram ( void **buf, unsigned int size );
void *release_ram ( void **buf );
#pragma long_calls_off
extern unsigned int *ptr;
unsigned int main (unsigned int msg)
   reserve_ram (  &ptr, msg * 4 );
   release_ram ( &ptr );
   return 0;
with following options
arm-elf-gcc -mthumb -save-temps -Os -Wall -c main.c
compiler assembled it to
  .code  16
  .file  "main.c"
  .text
  .align  2
  .global  main
  .code  16
  .thumb_func
  .type  main, %function
_main_:
  push  {r4, lr}
  ldr  r4, .L3
  lsl  r1, r0, #2
  ldr  r3, .L3+4
  mov  r0, r4
  bl  .L5
  mov  r0, r4
  ldr  r3, .L3+8
  bl  .L5
  @ sp needed for prologue
  mov  r0, #0
  pop  {r4, pc}
.L4:
  .align  2
.L3:
  .word  ptr
  .word  reserve_ram
  .word  release_ram
  .size  main, .-_main_
  .ident  "GCC: (GNU) 4.3.3"
  .code 16
  .align  1
.L5:
  bx  r3
SO i have a question, is any way to generate calls directly by bx/blx
instruction?. I mean something like this
_main_:
  push  {r4, lr}
  ldr  r4, .L3
  lsl  r1, r0, #2
  ldr  r3, .L3+4
  mov  r0, r4
  blx  r3
  mov  r0, r4
  ldr  r3, .L3+8
  blx  r3
  mov  r0, #0
  pop  {r4, pc}
regards,
Bartek
von (prx) A. K. (prx)
You need an ARMv5 architecture for the BLX instruction. If your have,
tell the compiler about it.
i have that architecture. Problem seems to be solved.
thanks,
Bartek
