Hi, as part of an assignment I have to write a PS/2 interface. Here's the code that I've written so far:
library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.NUMERIC_STD.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity ps2_if is port( clk, rst : IN std_logic; ps2_clk : IN std_logic; ps2_dat : IN std_logic; data_out : OUT std_logic_vector(7 downto 0); valid_out : OUT std_logic ); end ps2_if; architecture Behavioral of ps2_if is type State is (idle, receiving, transm_complete); signal CurrentState, NextState : State; signal goto_idle : std_logic; signal i : integer range 0 to 9 := 9; signal data : std_logic; begin process(clk, rst) begin if rising_edge(clk) then if rst = '1' then data_out <= (others => '0'); valid_out <= '0'; else if CurrentState = transm_complete then valid_out <= '1'; goto_idle <= '1'; elsif CurrentState = idle then valid_out <= '0'; goto_idle <= '0'; end if; CurrentState <= NextState; end if; end if; end process; process(ps2_clk, CurrentState) begin NextState <= CurrentState; case CurrentState is when idle => if falling_edge(ps2_clk) then NextState <= receiving; i <= i-1; end if; when receiving => if falling_edge(ps2_clk) then if i = 0 then NextState <= transm_complete; i <= 7; else data_out(i-1) <= ps2_dat; i <= i-1; end if; end if; when transm_complete => if goto_idle = '1' then NextState <= idle; end if; end case; end process; end Behavioral; |
The problem I don't really know how to solve is: even though the code seems to be correct to me the simulator wouldn't the data from ps2_dat to the data_out vector. As I don't know VHDL well, I'm struggling to find the mistake. I'm using the Xilinx Web Pack, v11.1 with the built-in simulator. Does anybody see what the problem is? Thanks a lot in advance! Martin
you couldn´t assign signals values in different processes!!
data_out <= (others => '0'); |
in the process above and
data_out(i-1) <= ps2_dat; |
so both process will work parallel and data_out will probably be 'X'?
A simple structure to describe processe in vhdl is
[vhdl]
XXX: process(CLK, NRES)
begin
if (NRES = '0') then
elsif (rising/falling_edge(CLK) then
end if;
end process
Hi waxology, thanks a lot. It is now working! The command
really seems to have been the problem. But when I remove it the vector won't be reset on a rst event. Could you tell me how to get that right? Another problem I noticed now is that valid_out which is supposed to be 1 for one clock cycle when all the bits have arrived only goes back to 0 after three cylces (clk cicles). Do you have any idea, why? Martin
process(ps2_clk, CurrentState) begin NextState <= CurrentState; case CurrentState is when idle => if falling_edge(ps2_clk) then ----------------<<< : end if; when receiving => if falling_edge(ps2_clk) then ----------------<<< : end if; when transm_complete => if goto_idle = '1' then NextState <= idle; end if; end case; end process; end Behavioral; |
You can try to simulate this, but you will never get it through the synthesizer.
process(ps2_clk, CurrentState) begin NextState <= CurrentState; |
CurrentState is combinatorial assigned to NextState, there's no clock or delay between. It's just the same. I don't think, thats what you really want :-/
CurrentState <= NextState; -------------------<<<
end if;
end if;
end process;
begin
NextState <= CurrentState; --------------------<<<
Hmmm...
This looks much like a infinte loop.
> It is now working!
Believe me:
You're much farther away from your destination than you may think :-o
You're not the first one to interface a keyboard to a FPGA, so have a
look around how others are doing the job ;-)
Hello Lothar Miller, thanks for the reply. I modified the first part you mentioned e.g. replacing the
if falling_edge(ps2_clk)... |
parts by one right at the beginning of the process. Concerning the signals of the FSM I also modified the code. And well, it passed the synthesizer. I think the main problem I have is that I have difficulties thinking in the hardware design way. That's why some parts of the code are somewhat strange.
You have to read FPGA Prototyping by VHDL Examples written by Pong p.Chu There are inside a PS2 interface example.
