Posted on: 2009-06-06 19:40
I am using Olimex's SAM7-P64 board, development tool set from YAGARTO
OPENOCD and Insight for my debugging. I sn suing USART1 and setup for
UART receive interrupt. The code starts and keeps looping in the main()
routine. When I enter a character (using Hyperterminal in XP PC) the
code stops at a debug break in the UART ISR. The ISR is coded as naked
function. When in ISR the LR shows a value of 0xC0. As a result when
returns from interrupt it does not go back to the main() routine. In the
beginning of ISR I've ISR_ENTRY() and at the end ISR_EXIT() macros.
#define ISR_ENTRY() asm volatile(" sub lr, lr,#4\n" \
" stmfd sp!,{r0-r12,lr}\n" \
" mrs r1, spsr\n" \
" stmfd sp!,{r1}")
#define ISR_EXIT() asm volatile(" ldmia sp!,{r1}\n" \
" msr spsr_c,r1\n" \
" ldmia sp!,{r0-r12,pc}^")
Also when in the ISR the processor mode is 0x13 which is supervisor mode
I thought I would see 0x12 the IRQ mode. Also at the beginning of the
ISR when SPSR is stored in R1, the SPSR[5:0] has value 0x33. The code is
compiled in ARM mode only.
Could anyone please help me in solving this problem.
Regards.
