Hello, as I'm still busy getting into VHDL, I'm every now and then encoutering problems where I don't really know how to solve them. I wrote a process which actually should evaluate the signals listed in its sensitivity list. Against my expectation it stopped after evaluating the first if statement (at least that's what I think as it didn't evaluate the rest of the process. Does anybody know how if statements are executed or what I could do in order to get right? Here's the code of the process:
btn_moved: process(west, east, south) begin if west = '1' then load1_ta <= '1'; buttons_west(3) <= west; buttons_west(2) <= north; buttons_west(1) <= east; buttons_west(0) <= south; end if; if east = '1' then load2_ta <= '1'; buttons_east(3) <= west; buttons_east(2) <= north; buttons_east(1) <= east; buttons_east(0) <= south; end if; if south = '1' then rst1_ta <= south; rst2_ta <= south; load1_ta <= '0'; load2_ta <= '0'; buttons_west(0) <= '0'; buttons_west(1) <= '0'; buttons_west(2) <= '0'; buttons_west(3) <= '0'; buttons_east(0) <= '0'; buttons_east(1) <= '0'; buttons_east(2) <= '0'; buttons_east(3) <= '0'; end if; end process btn_moved; |
Thanks a lot in advance! Martin
Processes are simply evaluated from top to bottom, nothing special
happening there. The state of a signal is determined by the last
assignment in a process, so if both west and south are '1', buttons_west
is "0000".
The best way to deal with unexpected behaviour is to use the simulator.
First you should write a test bench to feed your module with input
values and check the respective output values. If there is something
that doesn't work you can find out exactly what is wrong by
single-stepping through the code.
You can however not find any problem with the simulator. Only a strictly
synchronous design, i.e. a design that contains no or only clocked
storage elements (flip flops) works the same in real hardware as in the
simulator. In your code, you are describing a latch, which is an
asynchronous storage element and needs to be avoided. A latch is
generated because, if neither west, east nor south is '1', some of the
signals have to keep the value from before the process execution. The
only way to do that in hardware without a clock is a latch. If you need
that behavior, use a clocked process ("if rising_edge(clk)..."). If you
don't, give all signals default assignments at the start of the process.
Then the result of the process will only depend from its input
variables, not from the previous state of the signals, and you get a
simple logic network without latches.
Hi Martin
Sorry for my bad english.
You are watching on all 3 signals. First of all u have to think about :
* wich priority has each of the 3 signals
* can two or three signals = '1' at the same moment?
You dont use any Clk. That is not really good. Your Design-Software will
use some Latches.
I think the signals named rst1_ta rst2_ta load1_ta and load2_ta are
not correct assigned. Background:
1. west = '1' --> load1_ta = '1'
2. east = '1' --> load1_ta = '1' and load2_ta = '1' (Is this correct?)
I think the following code is a proper solution. But still without Clk.
begin
if west = '1' then
load1_ta <= '1';
elsif east = '1' then
load2_ta <= '1';
else --(when the previous statements are not treu)
rst1_ta <= south;
rst2_ta <= south;
load1_ta <= '0';
load2_ta <= '0';
buttons_west(3 downto 0) <= "0000";
buttons_east(3 downto 0) <= "0000";
end if;
Now thats the priority of the signals:
1. west
2. east
3. south or when none of the previos if-statement are true
Hopefully I thats helpfull.
Greetings
Martin
Just to make it complete .. one should carefully watch out since there is a priority issue
x <= 1; -- default, if a then x <= 2; elsif b then x <= 3; elsif c then x <= 4; else -- apparanty not needed, since default value above is provided -- but some like to express it explicitly end if; |
that's the same as
if c then x <= 4; end if; if b then x <= 3; end if; if a then x <= 2; else x <= 1; end if; |
x <= 1; if c then x <= 4; end if; if b then x <= 3; end if; if a then x <= 2; end if; |
if you want comb. logic make default assignment that's rule I always stick to it makes code more readable than having tons of if/else branches hope this was helpful
By the way, 'north' needs also to be in the sensitivity list.
Hi, thanks a lot for your replies. As I said I'm still busy learning VHDL so I was not aware of how if-constructions are processed. Eventually I solved the problem by rewriting the code in a different way where not that many if's are required. But thanks a lot anyway.
