Forum: FPGA, VHDL & Verilog Generic Adder in VHDL
von Martin (Guest)
Hello,
as I just started learning VHDL I still have a number of problems
getting things running.
I would like to write a generic adder which adds to input values bit by
bit.
In order to realize the generic functionality of the adder three
std_logic_vectors were introduced which contain the input and the output
(when the input was processed).
To check, if everything works correctly, I wrote a test bench. And
that's where the problems start. When running the syntax check I get an
error message telling me that n is not declared (in the section where
the signals are declared).
VHDL code of the test bench:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_unsigned.all;
USE ieee.numeric_std.ALL;
ENTITY adder_tb IS
END adder_tb;
architecture behaviour of adder_tb is
  component adder
    generic(n : integer := 4);
    port(
      x : IN std_logic_vector(n-1 downto 0);
      y : IN std_logic_vector(n-1 downto 0);
      sum : OUT std_logic_vector(n-1 downto 0 );
      cout : OUT std_logic
  end component;
  signal x_sig, y_sig, sum_sig : std_logic_vector(n-1 downto 0);
  signal cout_sig : std_logic := '0';
begin
    uut: adder PORT MAP (
          x => x_sig,
          y => y_sig,
          sum => sum_sig,
          cout => cout_sig
30
end behaviour;
Does anybody see the problem? Thanks very much in advace!!!!
von Morin (Guest)
The problem is in the line
n is not declared at this point. You have to add it as a generic or
local in adder_tb.
You might think that the line
declares n to be 4. However, this declaration is local to the component
'adder' and does not extend to the signal declaration for x_sig and the
like.
von Hartmut S. (scheff)
Hi Martin,
the error arises at the line
thats because your architecture doesn't know "n". "n" is defined in the
component part only and will be forwarded to "adder" only. So add a
"signal n : integer := 4;" before the signal definitions in the
architecture and it will run.
von Martin (Guest)
thanks for the quick reply. Unfortunately it didn't quite help. The
syntax check tells me there is a syntax error in the line where I
declare n and that n is still not declared in the line below. Seems
strange to me...
Sorry I was too fast: The correct answer ist "constant n : integer :=
4;". A signal can't do the job.
von Martin (Guest)
thanks a lot. It works!!!
von CHIRAZ (Guest)
Hi, I would like to implement a generic adder in VHDL  for integers does
any body can help me thank you.
What is the problem with your adder?
How did you find the problem?
What do you expect and wht happens instead?
Here "start" is not needed in teh sensitivity list:
PROCESS (clk,reset,start)
Why do you have a clock in your design?
   ELSIF(clk'event and clk='1') then
A adder is a completely logic device. There is no register needed.
