Forum: ARM programming with GCC/GNU tools Can read, can't write to ChaN's FATFs on AT91SAM7
Author: Travis Wiens (tkw954)
Posted on: 2009-05-12 23:52
First off, a big thanks to ChaN for developing the FATFs and Martin
Thomas for porting it to AT91.
I'm having some problems.  I can read files from a SD card, but not
fully write.  It opens the file and creates it on the disk, but fails
when I try to write with the error FR_NOT_READY.
I've attached a session dump below.
Does anyone have any ideas where to start?
I'm using Martin Thomas's port to a AT91SAM7S256 on a Olimex SAM7-P256
Rev E board and a Canon 32M SD card (although another card I have does
the same). I had to change the definition of SD_SOCKET_WP_PIN in board.h
to AT91C_PIO_PA25 to match the newer Olimex circuit. Compiled using the
latest gnuarm on linux.
Thanks in advance,
Travis
AT91SAM7S Demo Application by Martin Thomas
V1.0.3 5/2009
-- Compiled: May 12 2009 14:55:13 --
-- for Board SAM7-Pxxx
FatFs module test terminal
>di 0
rc=0
>ds
Power is ON
Drive size: 60800 sectors
Sector size: 512
Erase block size: 32 sectors
MMC/SDC type: 2
CSD:
00000000  00 5D 01 32 13 59 81 DA F6 D9 CF FF 16 40 00 7D
.].2.Y.......@.}
CID:
00000000  01 50 41 53 30 33 32 42 45 F1 45 69 0B 00 7C 5F
.PAS032BE.Ei..|_
OCR:
00000000  80 FF 80 00 ....
SD Status:
00000000  00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00
00000010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000030  00 00 00 55 50 00 00 55 00 20 07 00 75 01 07 1E ...UP..U.
..u...
>fi 0
rc=0 FR_OK
>fs
FAT type = 2 (FAT16)
Bytes/Cluster = 2048
Number of FATs = 2
Root DIR entries = 512
Sectors/FAT = 47
Number of clusters = 12001
FAT start (lba) = 64
DIR start (lba,clustor) = 158
Data start (lba) = 190
2 files, 10444800 bytes.
0 folders.
24002 KB total disk space.
13798 KB available.
>fl
----A 2009/05/12 16:01  10240000  TESTDA~2.DAT  testdata2.dat
----A 2009/05/12 15:52    204800  TESTDA~1.DAT  testdata1.dat
   2 File(s),   10444800 bytes total
   0 Dir(s),    14129152 bytes free
>fo 1 testdata2.dat
rc=0 FR_OK
>fr 10240000
10240000 bytes read with 2012 kB/sec.
>fc
rc=0 FR_OK
>fo 10 testwrite.dat
rc=0 FR_OK
>fs
Number of FATs = 2
Sectors/FAT = 47
3 files, 10444800 bytes.
0 folders.
13798 KB available.
>fw 2048 1
rc=1 FR_NOT_READY
0 bytes written with 0 kB/sec.
>fl
----- 1980/00/00 00:00         0  TESTWR~1.DAT  testwrite.dat
   3 File(s),   10444800 bytes total
Author: Martin Thomas (Guest)
Posted on: 2009-05-13 00:33
(1) Could you please try the write test without an "fs" between fo 10...
und fw?:
- (remove card/insert card or power off/on, not just reset of the AT91)
- fi 0
- fo 10 test
- fw 2048 1
- fc
- fl
(2) try with a lower the SPI-bitrate (increase prescaler)
(3) format the disk using the PC+Card-Reader or fm in the test-terminal
which calls ChaN's "makefs". Then retry with a "clean" system
Posted on: 2009-05-13 02:08
Thanks for the quick reply
>und fw?:
Same result:
>fi 0
rc=0 FR_OK
>fo 10 test
rc=0 FR_OK
>fw 2048 1
rc=1 FR_NOT_READY
>fc
rc=1 FR_NOT_READY
>fl
----A 2000/01/01 11:55         0  test
   1 File(s),          0 bytes total
   0 Dir(s),    27836416 bytes free
I changed
#define BOARD_PRESCALER         AT91C_PMC_PRES_CLK_2
in board_lowlevel.c to
#define BOARD_PRESCALER         AT91C_PMC_PRES_CLK_4
and
#define BOARD_MCK               48000000
in board.h to
#define BOARD_MCK               24000000
(I'm not sure if there are other changes to be made)
The result was exactly the same as before.
Reformatted with both Ubuntu's gparted and Panasonic's SD Formatter (on
XP) with the same result as before.
fm doesn't seem to work:
>di 0
rc=0
>fi 0
rc=0 FR_OK
>fl
   0 File(s),          0 bytes total
   0 Dir(s),    31080448 bytes free
>fm 0 16384
The drive 0 will be formatted. Are you sure? (Y/n)=Y
rc=1 FR_NOT_READY
>fs
rc=13 FR_MKFS_ABORTED
powercycle
V1.0.3 5/2009
>di 0
rc=0
>fi 0
rc=0 FR_OK
>fs
I then had to reformat the card to get it to work.
Posted on: 2009-05-13 09:35
Travis Wiens wrote:
> rc=1 FR_NOT_READY
Could you please re-check that your modification for the
"Write-Protect-Detection" works as expected? There is still some
test-code in sd_spi_at91 -> disk_init() for this, just replace #if 0
with #if 1. With this enabled the state of the socket-switches (CD and
WP) will be shown on the terminal-interface with "di 0".
> I changed
Just increase the value defined for SPI_SCBR_MIN in sd_spi_at91.c, keep
board.h as is.
> [pre]
>>di 0
> rc=0
>>fi 0
> rc=0 FR_OK
>>fl
>>fm 0 16384
> rc=1 FR_NOT_READY
I expect this and the "fw" problem have the same reason.
Do you have a scope? Could you try to monitor the supply voltage of the
card during the different tests?
Posted on: 2009-05-15 03:22
Martin Thomas wrote:
> Travis Wiens wrote:
>> rc=1 FR_NOT_READY
It works as expected, identifying if a card is present or not, and also
if the card is write protected or not.
>> I changed
> board.h as is.
Same result for SPI_SCBR_MIN ranging from 2 (default) to 8. (Doesn't
work at all for SPI_SCBR_MIN = 1.)
I don't have a scope, but I've got a 225 KHz daq system. If I can, I'll
take some measurements this afternoon.
Posted on: 2009-05-15 05:34
I've uploaded plots of Vcc during "fo" and "fw" commands to
http://picasaweb.google.com/tkw954/SAM7#
I've uploaded the raw data in Matlab format to
http://homepage.usask.ca/~tkw954/save_data3.mat
which includes 225 KHz data for Vcc DI DO and CLK for 'fl', 'fo', 'fw',
and 'di' commands.
The supply voltage does go below 2.5 V momentarily and seems to
oscillate between 2.7 and 3.8 V, especially at the end of the 'fo'
command.
If it would help, I can probably borrow a 'scope next week.
Posted on: 2009-05-15 18:13
> and 'di' commands.
> command.
Hmm, this reather wide span does not look "healthy" to me. What kind of
power-supply to you use? Maybe it's a little weak. Can you try with
another one?
I guess addtional measurements will not help that much. Test with a
"stronger" power-supply first.
There might be a software-issue but the few tests I made did not show a
problem (some outputs shown in the readme-file of the package). I will
do some more testing when I'm back at my "workbench" and will also scope
the card's vcc line.
Posted on: 2009-05-20 04:42
>another one?
I was using the USB powersupply, but get the same errors using a "wall
wart" rated for 2.1 A.
Author: Alex (Guest)
Posted on: 2009-09-11 14:33
und fw?:
- fi 0
- fo 10 test
- fw 2048 1
- fc
- fl
Ive had similar problems with card initialisation...if i remove and
re-insert the card it works fine.
It has to do with the card init..its not done correctly..did you find a
way to fix this problem?
Posted on: 2009-09-15 16:52
A new package of the AT91SAM7/ChaN FatFS demo-application is available
from my page:
http://www.siwawi.arubi.uni-kl.de/avr_projects/arm...
This - hopefully - includes a fix for the mentioned write problems. At
least all tests I have run with a SanDisk ultra II SDHC 4GB and
extrememory performance SD-Card 1GB worked as expected. If there are
still problems please disable DMA/PDC by a define in the
low-level-driver and try again. Feedback welcome.
Martin Thomas
Posted on: 2009-09-18 02:51
>from my page:
Yes, this solves my problems. Seems to work perfectly.
Thanks a lot,
Travis
Note: the original post is older than 6 Months.
webmaster@embdev.netContactAdvertising on EmbDev.net
